Thread: Header and manifold Thread
Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 261 to 280 of 325
  1. #1 Re: Header and manifold Thread
    The car is used to having a stock cat if you put one in that flows a lot better the car doesn't think there is a cat in there. You can tune the code out.
  2. #2 Re: Header and manifold Thread
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    Recently just put in ZZP headers and the 3 inch cat back and zzp mufflers. Good power gains also sounds mean but a real pain to put them in. Had to pull the valve the cover off and the tranny dip stick and once we got the back header in the tranny dip stick wouldnt mount back in its spot cause its caught on the crossover pipe. But dosent leak so, so far its all good. but other than that i love them a little expensive spent 1505.18 for everything headers, TOG down pipe, Stainless Cat back, Mufflers, Clamps, Bolts, Gaskets (manifold and flange) so other than its a pain its a real nice set up.
    97 GTP. ZZP CAI, ZZP Custom Dyno Tune, Drilled 180* Tstat, Voltege Booster, A104's, ZZP Wires, 3.4 Pulley, ZZP Stainless Headers with TOG down pipe, ZZP 3 inch Stainless Cat Back.
  3. #3 Re: Header and manifold Thread
  4. #4 Re: Header and manifold Thread
    and a catback
  5. #5 Re: Header and manifold Thread
  6. #6 Re: Header and manifold Thread
    Jul 2011
    Yeah it is a lot of money but it will never rust so basicly set for life so I see why there expensive but it makes one hell of a power gain tho.
  7. #7 Re: Header and manifold Thread
    Donating Users wulfpack06's Avatar
    KCMO
    Quote Originally Posted by JcGTP39 View Post
    you expect to have your grand prix for life?
  8. #8 Re: Header and manifold Thread
    Apr 2011
    Tally, FL
    yeah i hoping to do mine for $1300 Stainless steel all the way from the headers to the tips
  9. #9 Re: Header and manifold Thread
    Jul 2011
    Yeah stainless is the way to go..
    And I'm not to sure if I'm gunna keep it we not.. I was just using "set for life" as a figure of speech lol
  10. #10 Re: Header and manifold Thread
    stainless is much more expensive than aluminized steel and i would rather replace pieces along the way then put in that initial big sum for a catback that does nothing for the car, but make it sound poopy.
  11. #11 Re: Header and manifold Thread
    Jul 2011
    You save a 170$ with aluminized mind as well spend that extra for stainless if your doing all that work putting those headers in.
  12. #12 Re: Header and manifold Thread
    My headers and cat back only cost $200
  13. #13 Re: Header and manifold Thread
    Jul 2011
    Yeah but how does it sound?
  14. #14 Re: Header and manifold Thread
    No 3800 sounds good so i'll say mine sounds average.
  15. #15 Re: Header and manifold Thread
    Jul 2011
    Mine sounds pretty good. Has a nice rumble to it. But once you get till like 4500 rpm it starts to sound like a ricer.
  16. #16 Re: Header and manifold Thread
    Mine sounds fine at lower rpm but if you get on it at all it sounds horrible. I've had many people ask me how I put a v8 it in lol
  17. #17 Re: Header and manifold Thread
  18. #18 Re: Header and manifold Thread
    Jul 2011
    Haha yeah that's what it was like when I had mine just straight piped.
    Hey Bio do you have a diesel in Pontiac?!? There is no point to put 4 inch
  19. #19 Re: Header and manifold Thread
  20. #20
    Ohio
    Obvious?
  1. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  2. Another header thread just what we need...
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 11-09-2009, 12:18 AM
  3. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  4. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  5. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
