alldata is great.
Well heres the verdict I read up on a few different things I'm very busy with my work schedule and it's the only thing I have to drive so I went to ZZ performance and this is it:
Wizaired Cold Air Induction System
SeriesIII duct
K&N filter re-0870 fileter
ER Ratio Rocker Arms
HV3 Velocity Inkake Insert
Water Pump Underdrive Pulley
4T65e Shift Kit
Dextron VI Transmission fluid swap
304 Stainless Power log
180 thermostat w/thermostat gasket
with install totaled to $1852.70
Car sounds much more agressive and much more responsive I was told short of a turbo that was all they could do, except exhaust which I wouldn't see gains from unless I had the turbo that was it, we talked about the PCM and the gas gauge issue he said something about swapping out the fuel cannister back to the 05 style or something and to hold off on exhaust until I got the turbo w/intercooler, which with the injectors, the air to air intercooler, and the turbo itself he said I should see at least another 140HP, with install for right at $5000, but thats assuming that 05 PCM fix works.
