Yes you need 2 gaskets and 02 sensor bung. It is 2 nuts and 2 bolts to take out.
The only real problem with the swap is where it connects to the catback the bolts rust. When i did it on my car it required a torch to heat up the flange to be able to remove the bolts. If you can handle using an impact and a torch it can easily be done yourself or with the help of a friend.
Front and rear gaskets and any exhaust shop can do a bung into the pipe
probably cost 50 bucks or so
