Thread: I need a new cat converter, suggestions?
Results 1 to 20 of 25
  1. #1 I need a new cat converter, suggestions?
    Norristown, PA
    My low effiency cat code came up recently. my mechanic deleted the code and said to come back if it comes on again. Now its back again and i took the car to him. He quoted me $420 for a new cat, thats just the part price, not labor. I laughed and said i could get one cheaper..However i need suggestions..Stock GT btw.
  2. #2 Re: I need a new cat converter, suggestions?
    Donating Users Ibwrong's Avatar
    Oklahoma City
    do you have emissions? If not hack it off. You can get a replacement cat off ebay for cheap. 420 for a new cat, thats a rip off..
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: I need a new cat converter, suggestions?
    Jul 2008
    sumter,south carolina
    u can get a whole new downpipe with high flow cat for alot cheaper than that... ZZPerformance
    02 GTP with mods 05 GP for DD
  4. #4 Re: I need a new cat converter, suggestions?
    Norristown, PA
    i do have emissions, i saw on zzp a magnaflow one for $60
  5. #5 Re: I need a new cat converter, suggestions?
    Jan 1970
    Maquoketa, Iowa
    Take a sawzall, cut the cat out, then take a long rod or pipe and jam everything out until you can see through the cat. Then just have someone weld it back on and paint it so it doesn't rust. You will not have any more cat problems and its "legal".
  6. #6 Re: I need a new cat converter, suggestions?
    Jul 2008
    420 is a good number but i cant believe he quoted u that price... thats ridiculous.
  7. #7 Re: I need a new cat converter, suggestions?
    Apr 2009
    stockton ca
    isnt 420 the cat code aswell
    Just get a cat from zzp and have it welded in if you dont already have a dp nows the time
  8. #8 Re: I need a new cat converter, suggestions?
    Jul 2008
    Quote Originally Posted by wickedintent79 View Post
    lol yes it is..
  9. #9 Re: I need a new cat converter, suggestions?
    Norristown, PA
    I'm not going for performance. I just want to the job done and pass emissions. 420 is rediculous.
  10. #10 Re: I need a new cat converter, suggestions?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    id get the whole 3 downpipe with cat cause it also removes the crappy ubend.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  11. #11 Re: I need a new cat converter, suggestions?
    GTP Level Member tazyboy28's Avatar
    home town
    lmao 420 . . .wtf?
    im getting my downpipe replaced in my car with the header setup so if u havn't replaced it by then. then i geuss we can talk a price if its able to fit on your car. . . .
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  12. #12 Re: I need a new cat converter, suggestions?
    If you want fitment...and your not going for performance...just get a universal magnaflow cat off of fleabay for like $50-$75 or something like that. While your up there though...have the U-Bend taken out for sure. It'll give you better MPG's too just a FYI. But for christ's sake...take it to someone who knows their ass from a hole in the ground and not the same place that butchered your car earlier.
  13. #13 Re: I need a new cat converter, suggestions?
    Norristown, PA
    im going to order a magnaflow from zzp. I need the 2.5 right?
    and blue im NEVER going to monroe, this will be done at our family mechanic
  14. #14 Re: I need a new cat converter, suggestions?
    Topeka, KS
    Measure the pipe. You'd be better off going with the Downpipe with the cat though. It will make your car run peppier and give you better MPG. Just my $0.02
  15. #15 Re: I need a new cat converter, suggestions?
    Guam
    He is quoting you the stock replacement part plus his markup probably.
    Not a cut and splice in cat...
  16. #16 Re: I need a new cat converter, suggestions?
    420 is for a cheap cat system. Other cars have much more expensive stock bolt in replacements.
  17. #17 Re: I need a new cat converter, suggestions?
    Norristown, PA
    It's not the cat system. Just the cat converter. Which downpipe and cat should go for?
    A link would be nice.
  18. #18 Re: I need a new cat converter, suggestions?
    Apr 2009
    stockton ca
  19. #19 Re: I need a new cat converter, suggestions?
    $420 is for the downpipe... In other cars you have to buy larger sections of the exahaust so to save time i said cat system.
    Buy the ZZP downpipe already.
  20. #20 Re: I need a new cat converter, suggestions?
    Norristown, PA
    so if i order the 2.5in bolt on with cat, do i need a 02 bung or gaskets? also, could i install this myself? i never did any exhaust work and am limited in knowledge
  1. Cat Converter
    By VGPGT in forum General Tech Discussion
    Last Post: 08-30-2010, 02:20 AM
  2. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  3. 04 cat converter.
    By rcweldon988 in forum 04+ Specifics
    Last Post: 02-18-2009, 08:21 AM
  4. bad converter again
    By shawn in forum General Tech Discussion
    Last Post: 02-16-2009, 03:11 PM
  5. ZZP Converter doesn't line up ?
    By Meemperor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2008, 10:13 PM
