Thread: Cold problems
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Cold problems
    Guam
    First thing you need to do is take the battery out and have it charged up. Without a good strong charge in cold weather, it will be hard to start. Batteries can also freeze, I've had it happen, and you are better off bringing the battery indoors, if the car has to sit outside in these temps.
    Second, the car will not start unless the battery is fully charged.
    Also, what kind of weight oil are you using? 5W-30 or at least the 10W the is recommended? Oil becomes very thick in these temps too.
  2. #22 Re: Cold problems
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    he can't charge battery because th hod latch is frozen. damn, that sux
  3. #23 Re: Cold problems
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    My battery is good that was the other guy but I want to get my hood figured out before i go back to school and hopefully before i have a problem. Thank you guys for your help though I really appreciate it.
    silver 2003 Grand Prix GT List is on it's way to be updated
  4. #24 Re: Cold problems
    Guam
    Quote Originally Posted by badbrad View Post
    Yes I know, the advice was for either pseron once the hood WAS opened...
  5. #25 Re: Cold problems
    Guam
    Quote Originally Posted by kjohnson View Post
    I have read what you tried. Have you also tried having someone push down on the hood, lightly of course but with enough pressure, while you pull the cable lever inside the car?
  6. #26 Re: Cold problems
    Nov 2008
    Ya i did and i also adjusted the hood adjuster knobs so it would open easier. the handle wont even move unless ive been driving for a long time
  7. #27 Re: Cold problems
    White lithium >>>> everything else for hings and latches.
  8. #28 Re: Cold problems
    Nov 2009
    Nebraska
    Napa sells a antifreeze heater. I had to buy that and a new lower radiator hose. What ya do is cut the hose in half add in the heater. And BAM warm car faster. Also helps the car stay warm.
    Its gonna be -40 windchill..
  9. #29 Re: Cold problems
    Canada
    had a heater going about 2 hours and still nothing, this damn weather wont let up! still in the negatives
  10. #30 Re: Cold problems
    Nov 2008
    ya that is a great idea when im at home but im not able to plug in my car without like 1/4 mile of extension cords soooo yep that wont work. ive thought about putting one in my truck at home though. how much do they normally cost like 20 $??
  11. #31 Re: Cold problems
    SE Level Member 98GTPV8etr's Avatar
    Nov 2010
    Petawawa Ontario Canada
    A better fix for this than silicone spray or lithium is dry graphite comes in a can and works awesome for lubing parts in the extreme cold. I use it on my gps hinges and latches to make sure they work in the -1 to - 45 degree weather. Gotta love being a military mechanic who has access to new products to test
  12. #32 Re: Cold problems
    Charles City, IA
    Quote Originally Posted by 98GTPV8etr View Post
    Thats new in Canada EH? Its been in the US forever.
    SMGPFC Two Nipple General
  13. #33 Re: Cold problems
    its been in canada for a while as well...
    graphite comes in cans and in powder form.
    white lithium grease is the correct lubricant for your hinges/latches.
    and thanks for the epic necro.
  14. #34 Re: Cold problems
    Nov 2010
    wasn't saying that graphite was new to canada was just mentioning that we do get to try new and improved products apparently and the dry graphite was a new product blend according to the sales rep worked real well
  15. #35 Re: Cold problems
    new blend sure but dry graphite IS old news. Just carbon sheets, they slide on each other.
    Granted the structure is fairly consistent.
  16. #36 Re: Cold problems
    Nov 2008
    I just hope that this problem of mine went away. Ill have to check tonight I actually forgot that it was a problem until I red this
  1. Cold Air
    By TallassJonG in forum 5.3L V8 (LS4)
    Last Post: 12-05-2009, 07:10 PM
  2. Plugs too cold?
    By dirtmaster88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 11:35 AM
  3. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  4. Cold Air Intake Problems.... HELP???
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-06-2008, 05:56 PM
  5. Cold Air
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:15 AM
