I have the SAME problem.. I read the write ups and Replaced the wiper motor. The tab on my car was slightly bent so I bent it back to what I thought was perfect....I didnt really text it when I had it apart because I thought I had everything lined up right...
Before the wipers would stay up 100% when turned off. So I thought the motor was bad and the tab was bent...after fixing that today I got a chance to test them.
Now they work great except when on delay instead of them delaying at the bottom they pause at the top...and when turned off they go down where they should be on delay but do NOT retract down that last 4" or so....This is frustrating because when "off" they stick up a little....
Does this mean the tab is not bent correctly?!?! or is there some other control unit that needs replacing outside of the wiper motor?!?!?!
