Thread: hids in fogs....
Results 1 to 20 of 28
  1. #1 Re: hids in fogs....
    Dec 2008
    Lawndale, CA
    The threads I have read through out the forums is that the stock fog lamp housing melted because the HID bulb was longer than the halogen bulb and would touch the lens.
  2. #2 Re: hids in fogs....
    Nov 2009
    Grand haven
    I have the 8000k hid fog lights and they are starting to melt. They went from bright blue to a green tint cause they are stating to melt. If I only turn them on when i am driving they are ok. But if I have them on and just sitting after about ten min they get really hot. what are the best replacement foglight housing to buy where you can still ise your 880 bulbs?
  3. #3 Re: hids in fogs....
    Oct 2008
    Calgary, Alberta
    Blazer brand projector fogs with the clear lens (blue coating filters out blue light) will look small in fog light opening, but they have great output and a sharp cutoff for a fog light, and use the 800 series bulb.
  4. #4 Re: hids in fogs....
    Moore, Oklahoma
    Quote Originally Posted by 98gtp View Post
    Pilots fit a bit better I think. I believe the blazers with 3.5", I know my Pilots are 4". I just about ran the blazers before I found the pilots.
    Shawn W. Larsen
  5. #5 Re: hids in fogs....
    GTP Level Member SuperSport's Avatar
    Michigan
    Hey Iron Indian do you know where I can buy the 4 inch Pilots with the glass lens? I want to buy a set.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  6. #6 Re: hids in fogs....
    Dec 2008
    Lawndale, CA
    You can get them at walmart or pep boys for about $30 to $40. The one's I have used in the past have a blue lens.
    The part number for the pilots is NV-602W
    Other people have use the autopia fogs that can be found on ebay.
    97-03 PONTIAC GRAND PRIX HALO FOG LIGHTS lamps 98 99 00:eBay Motors (item 380192976723 end time Jan-29-10 17:37:15 PST)
    Also found these.
    97-2003 Pontiac Grand Prix Halo Fog Lamp Light Kit gtp:eBay Motors (item 390139167329 end time Jan-10-10 20:33:02 PST)
  7. #7 Re: hids in fogs....
    Michigan
    Quote Originally Posted by The Guz View Post
    Also found these.
    Do they make a set of the pilots in clear? I don't want blue.
  8. #8 Re: hids in fogs....
    SE Level Member pr84704p's Avatar
    Westchester, NY
    Quote Originally Posted by Iron Indian View Post
    Would this solution work for the 2004 models as well?
  1. how do i add fogs to 2006 gp
    By 2006gpdude in forum Visual/Body Modifications
    Last Post: 12-31-2009, 03:09 PM
  2. hid fogs
    By rojo grandprix in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 07:57 AM
  3. HID Fogs
    By GAFF in forum General Tech Discussion
    Last Post: 01-28-2009, 10:28 PM
  4. 880 HID Fogs
    By Berger in forum Visual/Body Modifications
    Last Post: 03-27-2008, 02:46 PM
