Thread: parking brake adjustment
Results 1 to 7 of 7
CMURDAx parking brake adjustment 12-27-2009, 12:40 AM
CMURDAx Re: parking brake adjustment 12-28-2009, 05:09 PM
TorqueAutoMotiv Re: parking brake adjustment 12-28-2009, 05:56 PM
TheyCallMeSteel Re: parking brake adjustment 12-28-2009, 07:15 PM
CMURDAx Re: parking brake adjustment 12-28-2009, 09:12 PM
TorqueAutoMotiv Re: parking brake adjustment 12-28-2009, 09:26 PM
Deimos Re: parking brake adjustment 12-29-2009, 08:04 AM
  1. #1 parking brake adjustment
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    How do i adjust my parking brake? The light is on on the dash, but the brake is not engaged. ive noticed on certain days my car wont even move without me hitting the gas from a dead stop, and when i let off the gas i start to slow down immediately and quick. anyone else had/have this problem?
  2. #2 Re: parking brake adjustment
    Toledo, Ohio
    no one has any info on how to adjust this?
  3. #3 Re: parking brake adjustment
    Apr 2009
    stockton ca
  4. #4 Re: parking brake adjustment
    SE Level Member TheyCallMeSteel's Avatar
    Chicago
    Did you try slamming it a few times?
  5. #5 Re: parking brake adjustment
    Toledo, Ohio
    i slammed it a bunch of times. ive used it since then. and that link didnt work.
  6. #6 Re: parking brake adjustment
    Apr 2009
    stockton ca
    Some times the links work sometimes they dont
    Park Brake Cable Service/Adjustment Disc Brake
    1. <LI type=1>Adjust the rear brake shoe and lining. Refer to Park Brake Shoe Inspection . <LI type=1>Apply and fully release the parking brake six times. <LI type=1>Verify that the parking brake pedal releases completely.
      • Turn ON the ignition. Verify that the BRAKE indicator lamp is off.
      • If the BRAKE indicator lamp is on, ensure that the parking brake pedal is in release mode and fully returned to stop. Remove the slack in the front parking brake cable by pulling downward on the cable.
      <LI type=1>Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle .
      <LI type=1>Adjust the parking brake by turning the nut on the equalizer (2) while spinning both rear wheels. When either rear wheel starts to drag, back off the nut one full turn.
      Important
      If the rear wheels rotate during the following test, adjust the parking brake shoe and lining. Refer to Park Brake Shoe Inspection .
      <LI type=1>Apply the parking brake to four clicks. Inspect the rotation of the rear wheels:
      • The wheels should not rotate forward.
      • The wheels should drag or not rotate backward.
      <LI type=1>Release the parking brake. Verify that the wheels rotate freely.
    2. Lower the vehicle.
  7. #7 Re: parking brake adjustment
    GTX Level Member Deimos's Avatar
    iowa
    did you check your brake fluid level? There someitmes iis a switch behind the paeking brake that sometimes goes bad or gets bent
  1. E-brake Replacement and adjustment
    By mustang gt in forum Introductions/Noob Questions
    Last Post: 08-02-2009, 11:42 AM
  2. Parking brake adjustment
    By ROTTMAN in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 10:35 PM
  3. Parking brake wire.?
    By KingOfTheSouth in forum General Tech Discussion
    Last Post: 01-18-2009, 07:34 AM
  4. parking brake broke
    By ionroller in forum General Tech Discussion
    Last Post: 01-03-2009, 11:10 AM
  5. How do you adjust your parking brake?
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2008, 07:08 PM
