Thread: Changing the wipers . . .
Results 1 to 16 of 16
  1. #1 Changing the wipers . . .
    Nov 2010
    Earth
    this is a really dumb question and I'm probably going to *facepalm* when you guys tell me how to do it :P
    I got new blades, and on every other car I've owned I was able to raise the wiper arm away from the windshield and swap 'em out, but when I went to do it on my '04 GP the back edge of the hood blocks the arms from swinging out . . .
    I also couldn't figure out how to get the blades to park in the up position because I figured 'up' is the way to do it but they would always return to the down position when I took the key out . . .
    so what am I missing?
    heh I'm willing to bet that this is a RTFM issue :P
  2. #2 Re: Changing the wipers . . .
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    Get in your car, turn the key to the ACC position and turn on your wipers and leave your door open. When they get to the up position turn the key to off and get out and then change them. That's how I do it anyway... I have an '04. Hope this helps!
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  3. #3 Re: Changing the wipers . . .
    Nov 2010
    Earth
    turns out I was pulling the stalk down for the quick wipe-once, which always parks the blades down no matter what
    it's all good . . . now to change my blinker fluid
  4. #4 Re: Changing the wipers . . .
    Charles City, IA
    Now blinker fluid, thats a mess to do.
    SMGPFC Two Nipple General
  5. #5 Re: Changing the wipers . . .
    GT Level Member 05CompG's Avatar
    Arizona
    Uhmmm i hope i dont get a face palm from this question bt...what is blinker fluid??
    Her Name...Stacii Dash
  6. #6 Re: Changing the wipers . . .
    Charles City, IA
    Its the fluid that collects in your headlights because gm can not make a set of headlights that dont leak.
  7. #7 Re: Changing the wipers . . .
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Its what mean old guys tell newbs to change when they want to screw with them.
  8. #8 Re: Changing the wipers . . .
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ hahaha. I have some of that now. Not near as bad as it was though and getting a new set of lights soon.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  9. #9 Re: Changing the wipers . . .
    dont forget to change the bumper fluid, change the air in the tires, and the almighty finagian pins, and while you are at the auto store pick me up a left handed screw driver.
  10. #10 Re: Changing the wipers . . .
    Muffler bearings.
  11. #11 Re: Changing the wipers . . .
    Nov 2010
    Earth
    while I'm there I guess I'll also see if they have a round tuit . . . I never have one when I need it
  12. #12 Re: Changing the wipers . . .
    Dacula, GA
    R.I.P.
  13. #13 Re: Changing the wipers . . .
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by Steel Armadillo View Post
    Muffler bearings.
    you dont want just any cheap offshore muffler bearings either...high speed timkens is the only way to go
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  14. #14 Re: Changing the wipers . . .
    Dacula, GA
    He might need some wiper blade sharpener for his new blades...
    R.I.P.
  15. #15 Re: Changing the wipers . . .
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    just fyi technically there is headlight fluid. some mercedes have wipers on the headlights. theres also a muffler bearing you can find them on the new ford gt and also i actually ordered a flux capaciter for a guy when i worked at autozone.
    2000 Daytona GTP(aka the slow fwd GTO)
  16. #16 Re: Changing the wipers . . .
    Dacula, GA
    Haha BUT! You've never had to sharpen wiper blades ;]
    R.I.P.
  1. Wipers don't work at all
    By kevinpope in forum General Tech Discussion
    Last Post: 09-12-2010, 01:10 PM
  2. wipers that won't park
    By flyboyray1 in forum General Tech Discussion
    Last Post: 01-21-2010, 01:53 PM
  3. wipers staying up
    By Jakegday in forum General Tech Discussion
    Last Post: 12-15-2009, 03:35 PM
  4. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  5. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
