Thread: PK3 keys?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: PK3 keys?
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    My 2001 GTP has it. Brand new key from the dealership cost me $30. I also have remote start and a regular key will NOT start the car.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  2. #22 Re: PK3 keys?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    My both my 2000 came with pk3
    98 regal PK2
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #23 Re: PK3 keys?
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by 02BlueGT View Post
    whoever installed your bypass wired it wrong, the bypay uses a factory key and an extension antenna, but should only be active when the remote start is active, the way the system is set up in you car seems that the bypass is always active, thus making the security key pointless, with about 50 seconds and a screw driver you could probably start the car......
    The quick remedy would be to open the dash, find the bypass and re-wire it so it is switched on/off by the remote starter
    Where is the "most likely" location (I should look) if any prior owner wanted to add a remote start module? PK3 (key) security system ? I know it is because I had to use the "30 Minute Relearn Procedure (Steps): This is for a "replacement" (new) key (no original available)"
    mentioned in this thread to clear the blinking "security light".
  4. #24 Re: PK3 keys?
    Halifax
    awesome. just tried it, it works.
