Thread: Hub ?
Results 1 to 5 of 5
  1. #1 Hub ?
    SE Level Member X97prixX's Avatar
    Idaho
    Ok I replaced my front passenger hub assembly and it all my warning lights went off on the dash. Now though when I hit a large bump or turn to sharp when it's cold the lights will come on. Plus little bumps or any pressure in turning slightly to that side will cause the low trac to light up. Did I install it wrong? or did I leave someting loose?
    I'm stumped...
  2. #2 Re: Hub ?
    Charles City, IA
    Check the connection for the abs sensor.
    SMGPFC Two Nipple General
  3. #3 Re: Hub ?
    GTX Level Member Deimos's Avatar
    iowa
    Those hubs can really only be installed one way. Granted you can install it worng but usually the wires won't reach...
  4. #4 Re: Hub ?
    Idaho
    I've checked the connector for the sensor and it seems to be tight
  5. #5 Re: Hub ?
    Idaho
    turns out the sensor was bad from the get go so I got it warranted and now it's fixed.
hub
