Thread: List of Torque specs
Results 1 to 20 of 22
  1. #1 Re: List of Torque specs
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Fastener Tightening Specifications
    Application
    Metric
    English
    Accelerator Control Cable Bracket Bolt
    16 N-m
    12 lb ft
    Air Injection Check Valve Pipe to Exhaust Manifold
    10 N-m
    89 lb in
    Air Injection Check Valve to Bracket Bolt
    25 N-m
    18 lb ft
    Balance Shaft Driven Gear Bolt
    22 + 70° N-m
    16 + 70° lb ft
    Balance Shaft Retainer Bolt
    30 N-m
    22 lb ft
    Camshaft Position Sensor Bolt
    10 N-m
    89 lb in
    Camshaft Sprocket Bolt
    100 + 90° N-m
    70 + 90° lb ft
    Camshaft Thrust Plate Bolt
    15 N-m
    11 lb ft
    Canister Purge Solenoid Valve Bracket Bolt
    50 N-m
    37 lb ft
    Canister Purge Vacuum Switch Bolt
    50 N-m
    37 lb ft
    Connecting Rod Cap Bolt
    27 + 50° N-m
    20 + 50° lb ft
    Crankshaft Balancer Bolt
    150 + 76° N-m
    111 + 76° lb ft
    Crankshaft Main Bearing Cap Bolt
    40 + 110° N-m
    30 + 110° lb ft
    Crankshaft Main Bearing Cap Bolt (Side)
    15 + 45° N-m
    11 + 45° lb ft
    Crankshaft Position Sensor Stud
    30 N-m
    22 lb ft
    Crankshaft Rear Oil Seal Housing Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Cylinder Head Bolt
    50 + 120° N-m
    37 + 120° lb ft
    Drive Belt Tensioner Bracket Bolt/Nut
    50 N-m
    37 lb ft
    Drive Belt Tensioner Bracket Stud
    6 N-m
    53 lb in
    EGR Valve Adapter Bolt/Stud
    50 N-m
    37 lb ft
    EGR Valve Inlet Pipe Bolt
    29 N-m
    21 lb ft
    EGR Valve Nut
    30 N-m
    22 lb ft
    EGR Valve Outlet Pipe Bolt/Nut
    29 N-m
    21 lb ft
    Engine Block Coolant Drain Plug
    30 N-m
    22 lb ft
    Engine Block Oil Gallery Plug
    30 N-m
    22 lb ft
    Engine Coolant Temp Sensor
    23 N-m
    16 lb ft
    Engine Flywheel Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Engine Front Cover Bolt Stud
    20 + 40° N-m
    15 + 40° lb ft
    Engine Lift Bracket Bolt/Nut./Stud
    30 N-m
    22 lb ft
    Engine Mount Nut Lower
    78 N-m
    58 lb ft
    Engine Mount Nut Upper
    78 N-m
    58 lb ft
    Engine Oil Pressure Indicator Switch
    16 N-m
    12 lb ft
    Engine Wiring Harness Heat Shield Nut/Bolt
    10 N-m
    89 lb in
    Exhaust Crossover Heat Shield Nut
    20 N-m
    15 lb ft
    Exhaust Crossover Pipe Bolt/Stud
    18 N-m
    13 lb ft
    Exhaust Manifold Bolt/Nut
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Inner)
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Outer)
    10 N-m
    89 lb in
    Fuel Injector Rail Nut
    10 N-m
    89 lb in
    Fuel Injector Rail Stud
    25 N-m
    18 lb in
    Fuel Injector Sight Shield Bracket Nut
    30 N-m
    22 lb ft
    Generator Brace Bracket Bolt
    50 N-m
    37 lb ft
    Heated Oxygen Sensor
    42 N-m
    31 lb ft
    ICM Nut
    50 N-m
    37 lb ft
    ICM Stud
    6 N-m
    53 lb in
    ICM Wiring Harness Bolt
    2 N-m
    18 lb in
    Idler Pulley Bolt
    50 N-m
    37 lb ft
    Idler Pulley Bracket Bolt
    30 N-m
    22 lb ft
    Lower Intake Manifold Bolt
    15 N-m
    11 lb ft
    Oil Cooler Adapter Connector
    50 N-m
    37 lb ft
    Oil Filter
    30 N-m
    22 lb ft
    Oil Filter Adapter Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Oil Level Indicator Switch
    20 N-m
    15 lb ft
    Oil Level Indicator Tube Nut
    19 N-m
    14 lb ft
    Oil Pan Bolt
    14 N-m
    125 lb in
    Oil Pan Drain Plug
    30 N-m
    22 lb ft
    Oil Pump Cover Screw
    11 N-m
    98 lb in
    Oil Pump Screen Bolt
    15 N-m
    11 lb ft
    Power Brake Booster Heat Shield Nut
    20 N-m
    15 lb ft
    Spark Plug
    27 N-m
    20 lb ft
    Starter Motor Heat Shield Bolt
    30 N-m
    22 lb ft
    Throttle Body Nut
    10 N-m
    89 lb in
    Throttle Body Support Bolt
    10 N-m
    89 lb in
    Throttle Body Support Stud
    6 N-m
    53 lb in
    Timing Chain Dampener Bolt
    22 N-m
    16 lb ft
    Upper Intake Manifold Bolt/Stud
    10 N-m
    89 lb in
    Vacuum Solenoid Valve bolt (with NC1 California Emissions)
    10 N-m
    89 lb in
    Valve Lifter Guide Retainer Bolt
    30 N-m
    22 lb ft
    Valve Rocker Arm Bolt
    15 + 90° N-m
    11 + 90° lb ft
    Valve Rocker Arm Cover Bolt
    10 N-m
    89 lb in
    Water Outlet Bolt
    27 N-m
    20 lb ft
    Water Pump Bolt
    15 + 80° N-m
    11 + 80° lb ft
    Water Pump Pulley Bolt
    13 N-m
    116 lb in
    Wiring Harness Shield Bolt/Nut
    10 N-m
    89 lb in
  2. #2 Re: List of Torque specs
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    WOW thank you very much, that was way more than I expected. Now maybe we can get a sticky made with that info in it.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. 3800 Torque Specs [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 08-24-2013, 01:24 AM
  3. Updated 4T65E Info Page! Torque Specs Added
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2012, 12:13 PM
  4. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
  5. Possibly Add Torque under edit details
    By JashGTP in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 10:22 PM
