Thread: Need HID help, with pics
Results 1 to 12 of 12
  1. #1 Need HID help, with pics
    Norristown, PA
    i understand all this, but where do those two metal connectors go?
    these are for projectors by the way, im using stock harness
  2. #2 Re: Need HID help, with pics
    GXP Level Member
    Theworld
    Those are for the regular headlight bulbs.
  3. #3 Re: Need HID help, with pics
    GT Level Member BackInBlack's Avatar
    Vermont
    That kit looks to be for H1 or H3 bulbs. What are you installing into?
    The GPs are long gone...
  4. #4 Re: Need HID help, with pics
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    I just cut the ends off and slid them thru the rubber grommet. I ended up making my own harness out of a heavier gauge wire then what came with the projectors with that I put in a 9006 connector so I didn't have to "connect" to the projector harness.
    In regards to your diagram...
    This is going to be hard to explain... The 2 wires on the projector harness that go to the H1 (low beam), connect those two wires to the wire ends you have circled. Then the 9006 connector (the other one you have circled) goes to the ballast.
  5. #5 Re: Need HID help, with pics
    Norristown, PA
    There H1 and for projectors
  6. #6 Re: Need HID help, with pics
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by rocafella2032 View Post
    The two connectors on the top right that go the HID bulb plug into the similar connectors coming from the ballast. The ballast should be connected to the factory headlight connector. The plug on the top left with the two wires that are circled could probably be used for the high beams on the projectors. The two wires circled can be tapped into the high beam wire and ground wire from the factory wiring. Do you have pics of the ballast just to be sure.
  7. #7 Re: Need HID help, with pics
    Norristown, PA
    how do i plug anything into the factory 9007 when the projector had to be plugged into that?
  8. #8 Re: Need HID help, with pics
    Dec 2008
    Lawndale, CA
    A pic of the ballast would help. But the 9007 plug should fit into the ballast connector. Nevermind I forgot we have that big blue connector. I have mine on a relay harness so its different from your set up.
  9. #9 Re: Need HID help, with pics
    Joliet, IL
    PLUG THOSE TO THE 2 WIRES THAT GO TO THE ORIGINAL BULB IN THE PROJECTOR they are blue and black and come from the harness for the projectors
    when you remove the rubber cap on the back of the projectors there are two wires going through that cap, plug your two wires that are lost into those they do not fit perfectly size wize as one of male connectors is smaller but just pinch the female connectors tight before puttin in the male connectors.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  10. #10 Re: Need HID help, with pics
    Joliet, IL
    the original wires to the old halogen bulb are now the power source for the ballasts....wires that come off the original halogen bulb in the projector go to those connectors....
    00 Silvermist GTP
  11. #11 Re: Need HID help, with pics
    Joliet, IL
    if this doesnt clear it up....im sorry but i give up....
    00 Silvermist GTP
  12. #12 Re: Need HID help, with pics
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by BoostJunki3 View Post
    Awesome Paint FTW!!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  1. Pics, let me know what you think!!
    By boomboom in forum Visual/Body Modifications
    Last Post: 08-12-2009, 11:29 PM
  2. Few Pics
    By jimmyjam33 in forum Visual/Body Modifications
    Last Post: 07-24-2009, 03:22 AM
  3. Pics of my car and others
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 03-09-2009, 08:57 PM
  4. Pics of the GTP
    By Mikel2k7 in forum Visual/Body Modifications
    Last Post: 08-13-2008, 01:08 PM
  5. You asked for them... pics pics and more pics!
    By miller in forum Off Topic Discussion
    Last Post: 07-30-2008, 05:33 AM
