Thread: Projector HID
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Projector HID
    Norristown, PA
    Anyone have a picture installation on these? Or does anyone have pictures of there setups? still stumped, feelin' like a ra-tard
  2. #2 Re: Projector HID
    Norristown, PA
    bump?
  3. #3 Re: Projector HID
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    You going to try again eh? Good for you... Can't add anything more to what we discussed the last time...
    Where are you at now with your install?
  4. #4 Re: Projector HID
    Norristown, PA
    well i talked to a few more people, and i got the understanding of most of it, except the two connectors. Also someone mentioned adding a ground, or splicing or something. Id hate to give up on these but a picture might be all i need
  5. #5 Re: Projector HID
    Kansas
    roca what issue are u having?
    SOLD 1999 GT Silvermist TS
  6. #6 Re: Projector HID
    Norristown, PA
    Well, i basically have no idea how to get these in. Cant understand why i dont get it, everyone says there so simple..Please tell me you can help me out. Ill paypal ya $5
  7. #7 Re: Projector HID
    Kansas
    no need for the five dollars.. Can you take a picture of your projector and then ur hid and ill tell you what goes where
  8. #8 Re: Projector HID
    Apr 2009
    Carlisle PA
    Physically into the projector? You'll probably have to grind down the hole in the projector a little bit on the sides. PM me your number and I'll call ya... Have my old harness in hand...
  9. #9 Re: Projector HID
    Norristown, PA
    This is them, I have the same projectors as you grafford. Halos wired to the parking lights and the H1 bulb harness connected to the stock harness
  10. #10 Re: Projector HID
    Kansas
    ok the two that say where do these go... What you do is u take out the bulb that exists in the housing now and there will be one wire connected to the bulb and then one connected to the mount.. Disconnect both of them. Then you plug the blue and black wires into the two wire that you just disconnected.
  11. #11 Re: Projector HID
    Norristown, PA
    so those two connectors will go into the spot the h1 bulb was in? and what goes into the stock harness? do i leave the plug already connected
  12. #12 Re: Projector HID
    Kansas
    well they connected to the two wires there were connected to the H1 Bulb
  13. #13 Re: Projector HID
    Apr 2009
    Carlisle PA
    Snip off the connectors on the blue and black wires going to thru the rubber plug. Pull those wires thru the plug. Now, on the harness (9007 plug) that came with the projector, you have a red and black wire setup, that goes to your 9005 high beam bulb...
    Now you have 2 other wires coming from that 9007 plug a blue and black wire, with female spade connectors. You have the other set of wires (blue/black) that you just removed from the rubber plug, connect the blue to the blue and black to black... (I'd just remove the female spade connectors and just tie them together or the time being and covered with electrical tape)
    The connector at the then end of the blue/black wire gets plugged into ballast...
  14. #14 Re: Projector HID
    Norristown, PA
    Quote Originally Posted by BlownBigBlock View Post
    that was incredibly confusing to me. Thats why i think i may need pictures if i want to get them in.
  15. #15 Re: Projector HID
    Norristown, PA
    and i just plug them in? simple as that?
    could you take any pics of it? i mean you do have that nice camera and all lol
  16. #16 Re: Projector HID
    Kansas
    woah dont snip anything!!!!!!!!
  17. #17 Re: Projector HID
    Kansas
    Its 10:50 here and i have a game tomorrow. But i dont have my car anyways cause the hood is getting painted .. I can take pictures on friday for sure for you.. but please please dont snip at anything
  18. #18 Re: Projector HID
    Apr 2009
    Carlisle PA
    Hold on, I'll get a picture...
  19. #19 Re: Projector HID
    Norristown, PA
    I will wait, i dont have time to install til friday as well. I appriate both of your help you guys. lets hope i can finally get this
  20. #20 Re: Projector HID
    Kansas
    There are two female connectors on the H1 Bulb.. one on the back of the bulb and one on the little bracket that holds the bulb in place.. Pull both those off the bulb and connect to the Blue and Black male connectors on the HID Wires
  1. I need projector help
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-30-2011, 07:47 AM
  2. Projector Question??????
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 08-13-2009, 09:56 PM
  3. projector headlights
    By musiknjoyr in forum Visual/Body Modifications
    Last Post: 03-01-2009, 04:08 PM
  4. projector headlights
    By 3800SE in forum Visual/Body Modifications
    Last Post: 10-15-2008, 07:57 AM
