Thread: Please Help!!. My car won't start
Results 1 to 8 of 8
  1. #1 Please Help!!. My car won't start
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    I'm ticked off. I just took off my supercharger and ported it. Went to put everything back together and the car won't start. It cranks and fires and literally dies a split second later as if I turned it on and turned the key right back off. Fuel pump is brand new. Fuel filter is brand new. Coil wires are in the right spots. All the electrical connections have been put back together. Everything worked fine until After the supercharger was re-installed. I just want my baby back on the road ASAP. I'm going to scan for codes today and post if anyhing pops up.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: Please Help!!. My car won't start
    Outer Space
    double check all your connections again and spark plug wires. Also, do you hear the fuel pump make noise before you crank it?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Please Help!!. My car won't start
    Nov 2009
    Michigan
    Quote Originally Posted by Lawngoose View Post
    I've double checked all of the connections and my fuel pump does make the humming when I turn the key on. I'm stomped.
  4. #4 Re: Please Help!!. My car won't start
    Outer Space
    The only other thing I could think of is a severe vacuum leak under the supercharger... maybe some others will chime in.
  5. #5 Re: Please Help!!. My car won't start
    Nov 2009
    Michigan
    Thanks anyway for the suggestions...Under the supercharger? By that do you mean on the left side by the snout?
  6. #6 Re: Please Help!!. My car won't start
    Outer Space
    Quote Originally Posted by OrangeL67 View Post
    The supercharger has a big gasket under it, that sits on top of the Lower intake. I had a bad leak in mine one, and it made my car stall. Can you not keep the car running with your foot on the gas? Definitely get the car scanned for codes too.
  7. #7 Re: Please Help!!. My car won't start
    Nov 2009
    Michigan
    Just got it running. The Supercharger gasket was leaking coolant near the O rings and I had some cracked vacuum lines. All is well and she's screaming like she loves me.
  8. #8 Re: Please Help!!. My car won't start
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    cool
  1. 04 gtp, tic tic tic tic when trying to start
    By busagtp in forum General Tech Discussion
    Last Post: 08-31-2009, 08:26 AM
  2. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  3. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
  4. Help car won't start
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 05:48 PM
  5. Let me start over
    By vermsta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2008, 06:02 PM
