Thread: please help!!!!!!!!
Results 1 to 10 of 10
  1. #1 please help!!!!!!!!
    SE Level Member bensett004's Avatar
    michigan
    ok so i just got home from work its 4 in the morning and i havent drove my car in 2 days, its been pretty cold.....so i went out to start it and it started hard....but started, so i let it run for like 10 min, shut it off....i wanted to start it back up because my battery seemed week and i want to see if it would start again, turned it over and nothing........just cranks.....any suggestions?
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  2. #2 Re: please help!!!!!!!!
    GTX Level Member cerick08GP's Avatar
    Well, cold weather will finish off a weak battery. My advice is use a battery charger, a fully charged battery should light your car up. But plan on buying a new battery soon., especially if its over 5 years old.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: please help!!!!!!!!
    Donating Users Ibwrong's Avatar
    Oklahoma City
    But if its cranking it wouldn't be the battery.
  4. #4 Re: please help!!!!!!!!
    Quincy, Mass
    frozen fuel? premium should be fine unless you go to a crappy gas station with really watery gas.
    No more GP 04 Impala SS Indy:
  5. #5 Re: please help!!!!!!!!
    Wooster, Ohio
    Quote Originally Posted by Ibwrong View Post
    not true, if its cranking slow with a bad or weak battery it can send the ECU mixed and improper signals and voltage, causing a no start.
  6. #6 Re: please help!!!!!!!!
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    maybe check the ign. control module or fp relay/resistor whatever. if it turns over good u know its not the charging system.
  7. #7 Re: please help!!!!!!!!
    michigan
    Ended up bein fuel pump.....confused the crap out of me.....it ran finr then nothin.....so 270$ later it runs fine...thanks for the help
  8. #8 Re: please help!!!!!!!!
    MO
    fuel pumps are tricky like that. comes out of NOWHERE
    <brandonl2000> LMAO D!!
  9. #9 Re: please help!!!!!!!!
    New Mexico
    We used to have 1999 2 door Tahoe's at work, and the fuel pumps were a common problem...it was funny, you would walk out to the parking lot and hear everybody tapping the fuel tanks. Sometime it helped the pump, other times it didn't!
  10. #10 Re: please help!!!!!!!!
    Donating Users ARFF22's Avatar
    NEW YORK
    Quote Originally Posted by AZGXP View Post
    Exactly what I did for my Bronco. Carried around a hammer with me and when it started acting up, gave the tank a couple of hits, and it worked fine for a couple of days. Eventually, the pump died totally, luckily in the driveway!
