Thread: Low Voltage Light
Results 1 to 9 of 9
  1. #1 Re: Low Voltage Light
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    Quote Originally Posted by DanGTP View Post
    You can't trust that method with newer cars. Some have built in safety measures that will kill the car if the battery is unhooked. Also, you chance maiming your PCM.
    OP, go have your charging system checked. Usually a light like that is a sign of a failing or failed alternator. It's also possible that you simply have a loose wire somewhere in the charging system.
    Im not talking about most cars im talking about his gp...ive done it hundreds of times.it would just be like if the battery when completely dead what would the diff be plz inform me...and if it did your telling me it would fry the comp??i doubt it...I didnt say disconnect the terminal and throw it around the engine bay....or ground it out on somthing..all you do is loosen it and quikly lift it off and if it starts to die press it back on. if it does start to die its your alt if it stays running its your battery then you get which ever it is tested just to double check. its an old mechanics trick.....i guess you learn somthing new everyday bc i didnt know there was any sensor incase the battery was disconnected guess its on the same car with the battery fluid light idk lol....i know a lot of things are electronicly controlled on the newer cars but this trick does work and will help if done properly...im not saying its the best way to do it a meter or tester is always better but doing this trick WILL point you in the direction needed to start diagnostics.....Ive had the main positive wire on my 2001 truck short out on the body meaning it was routed through the body panel and from vibration cut itself totally groundint out and didnt fry a single sensor or anything so i doubt doing what i said will hurt anything...and again im not saying to throw it around the engine bay....good luck guys....
    If you cant manage to do this on your car/truck then u def shouldnt even open the hood..... no offense to the op...
  2. #2 Re: Low Voltage Light
    PA
    Quote Originally Posted by bigdawg15005 View Post
    Wow, that was hard to read.
    But no, on today's newer computer controlled vehicles, disconnecting the battery while the car is running in not advised. In the older days when vehicles had less electronics and were not as sensitive to voltage fluctuation, this was not an issue. I remember my dad doing it on our old 71 Jeep. But with today's sensitive PCM and electronic injectors and sensors, disconnecting the batter while the alternator is trying to charge the system can result in a very sharp voltage spike. This can definitely cause issues with your PCM, injectors, and other sensors.
    So again, while this may have been an old mechanics trick from years ago, it is not recommended on today's newer computer controlled vehicles. Please don't offer this advice anymore.
    2001 GSE
  1. HID and DRL low voltage Ficker
    By massivesystem in forum Visual/Body Modifications
    Last Post: 04-17-2009, 02:00 PM
  2. Alternator voltage boost
    By abuckley1290 in forum General Tech Discussion
    Last Post: 04-04-2009, 02:21 PM
  3. Idle voltage....Alternator?
    By Damojo2003 in forum General Tech Discussion
    Last Post: 12-05-2008, 06:52 AM
  4. fuel pump voltage
    By theone2043 in forum General Tech Discussion
    Last Post: 11-10-2008, 01:35 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
