Thread: GTP supercharger problems
Results 1 to 11 of 11
  1. #1 GTP supercharger problems
    United States
    Hello all,
    I just recently acquired a 1998 GTP with 114000 miles on it. The previous owner had removed the supercharger belt, so my first move was to replace it, now the engine seems to be misfiring and stuttering after about 2000 rpm, if I remove the belt, the problem (and the power) are gone.
    Any suggestions would be greatly appreciated, TIA
  2. #2 Re: GTP supercharger problems
    Oct 2008
    Calgary, Alberta
    Whate grade fuel is in it? regular or premium w/o belt regular would be fine , regular is not good with the supercharger belt on.
    Any engine codes? engine light flashing when the car sputters?
    Do a basic tune up at the least, plugs and wires. When plugs removed inspect them.
    All test drives had a slight sputter around 3-4000+ rpm under boost thought must be nomal. My 98 gtp I got last year got a code for missfire and it was a bad plug, there was a hairline crack in the ceramic.
  3. #3 Re: GTP supercharger problems
    United States
    I have been putting premium gas in, the service engine soon light comes on ocassionaly with or without the belt, but started flashing when the engine was sputtering. I have only had the car for week now, just trying to fix all of the problems big and small that the last owner left for me.
  4. #4 Re: GTP supercharger problems
    Wichita
    Got bad spark plugs/wires/coils? Check the catalityc converter & fuel system?
  5. #5 Re: GTP supercharger problems
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    tune up! tune up! tune up! plugs (with correct gap), wires, air filter, fuel filter, pvc valve, seafoam in the gas tank.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  6. #6 Re: GTP supercharger problems
    Wausau, WI
    tune up and if the code continues, get the code retrieved and post it here. Then we can trouble shoot.
  7. #7 Re: GTP supercharger problems
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    welcome and it may be something fubared in the sc itself. can u spin the sc pulley without much resistance or what?
  8. #8 Re: GTP supercharger problems
    United States
    The supercharger does spin freely with almost no resistance, still waiting for my buddy to get back into town w/ my diagnostic so I can get the codes.
  9. #9 Re: GTP supercharger problems
    Nov 2009
    Grand haven
    just goto autozone they will do it for free..
  10. #10 Re: GTP supercharger problems
    Guam
    Do not put any parts into until you get the code read and find out what is going on.
    If you just start throwing parts at it, you could be wasting money.
    Put the belt back on get the code read and at the same time observe all the other engine functions on teh scanner or have someone else do it. This car needs a trained technician, not an auto zone free scan, or else the issue(s) could stay. You should possibly take it to the dealer to at least figure out what is wrong and THEN fix it on your own.
  11. #11 Re: GTP supercharger problems
    Charles City, IA
    Quote Originally Posted by toolguy View Post
    Come on the autozone scan tool is way better than the modis
    lol I love that thing. Wish I have 10K to drop on one and all the goodies for it for home. Oh well I will just use it at the shop.
    SMGPFC Two Nipple General
  1. Supercharger
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 06:24 PM
  2. supercharger
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 03:47 AM
  3. supercharger
    By sUpErClEaNbLaCkMaChInE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 01:50 PM
