Thread: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
Results 1 to 20 of 37
  1. #1 Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    My AC and Heat works just fine, and the blower does blow air, but it has never been as powerful as any other vehicle I have ever owned. It also has always made a little noise (not air, but more of a slight gritty/grinding noise), nothing really loud, but certainly not just air flow.
    Are all blower motors "lower flowing" like mine?
    Would replacing it help, or are they just somewhat weak to begin with?
    I am assuming the slight noise is the motor, so if a new motor will really blow the air, then I can solve 2 problems at once. If I won't get any better air flow, then I'll just deal with the noise as it isn't TOO bad.
    Thanks!
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  2. #2 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Ocala, FL
    Well, I thought there was something wrong with mine because it doesn't blow very hard.. though it does get louder..
    Maybe it's normal, I dunno.
  3. #3 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    new orleans
    i have the same problem....idk..
  4. #4 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    mine sucks too
  5. #5 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Apr 2008
    Marion, Iowa
    Quote Originally Posted by bonerjamz03 View Post
    mine sucks too
    Wow. Mine at least blows, yours is sucking air in? Crazy!
  6. #6 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    mine seems to work great on all setting except the floor.. it's still movin air but not as much as i'm use to. on my park ave with the setting on the floor it heats up hotter than hell. put it on the floor in the gp and it gets like luke warm
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  7. #7 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    only complaint i have with mine is that hardly anything ever comes out of my far left vent, the one above the headlight switch. other then that vent, mine blows great
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by Jakegday View Post
    Same, and I can also hardly feel anything out of the floor heater.
  9. #9 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    mine compleatly went out .
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  10. #10 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    SE Level Member trickytransam's Avatar
    Michigan
    Have you tried replacing the Blower Motor resistor? The stock ones have circuit traces that deteriorate over time.
  11. #11 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Apr 2008
    Marion, Iowa
    Does the Blower Motor resistor help with the amount of air that flows? I thought that was just if your blower quit...
  12. #12 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Michigan
    It's just a thought. I've replaced one in a co-workers car when he lost all but high speed on the fan. When I pulled it out all the traces were corroded and the fan on high was like a mouse coughing.
    So if the fan isn't spinning the squirrel cage fast enough, it may not push out enough air.
    We put in the new blower motor resistor, and it was like better than new.
    It could be that the HVAC doors aren't fully closing due to a weak vacuum actuator.
    If it's common that there's not much air coming out, then I'd say it's normal.
    My TA has the most amount of air coming out of it that I've ever had on a vehicle. You can blowdry your hair in the car if you had to.
    Might be a stronger motor. Unfortunately not the same part number
    02 TA P/N BM10027
    01 GP P/N BM10019
    Mabee compare the mounting and cage height.
    Just some thoughts.
  13. #13 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Denver
    Quote Originally Posted by nickbuol View Post
    I don't have a wiring schematic in front of me, but my guess is that a bad resistor can affect ALL speeds.
    My guess is that it's nothing more than a system of ballast resistors more or less that knock down the voltage heading to the motor (from a constant line side feed) and adjust its speed. So, if you have a bad resistor assembly with increased resistance, the voltage heading to your blower motor will decrease and so will the motor's speed.
    One way you should be able to check is to yank the blower motor, check a schematic (should be in your Hayne's manual) to find the high speed terminals and run if off of a +12VDC source (I assume there are no transformers etc).
    My wife's car (2005 Monte) had a bad resistor assembly. Her blower motor was slow and wouldn't respond to the controls a lot of times. It would take ~10 min for the fan to actually start. The motor was fine - with a replacement resistor pack it fired right up and now works flawlessly.
  14. #14 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    tennessee
    have you checked your cabin filter over time they to can rescript the amount of flow.
  15. #15 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    May 2008
    staten island,NY
    there are no cabin filters installed on the GP's. if you go to buy one ask for one from a 99 regal. thats how it is here in NYC, maybe its different by where you guys live. the guy at the parts counter looked at me like i was crazy.
  16. #16 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    SE Level Member gpgtp99's Avatar
    Canada
    i have the same problem, its frustrating to start the car 10-15 minutes before at only -5 -10c to dont look like mister freeze in the car
  17. #17 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Quote Originally Posted by QwikGT View Post
    at my work it lists one.
  18. #18 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    So, do we have cabin filters from the factory, then? I thought it was something that could be installed later on, but wasn't there when the car was new. If so, how do we access it? Is it from the outside on the passenger side cowl?
    If not, then I am planning to take a look at the blower motor, itself. It seems like it's vibrating a lot when turned up past the 4th setting and hardly moves any air, to speak of. If it's not an OEM part, then I'll replace it with an AC Delco while it's out. Does anyone have a P/N for it on a '99 GTP with the dual digital climate control? My cost at the local dealership is $150, but I am betting it can be had for less somewhere else if I can get my hands on the right one.
  19. #19 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    I live here. TLSheff's Avatar
    Quote Originally Posted by SnowDrift View Post
    No cabin filters from my gm catalog showing up, so doubtful its a factory option, but anything can be setup if you have the drive and $$$ to do it.
    Part number (im assuming you meant for the blower motor) is a GM# 19131212, ACDelco #15-80664. But it shows list at $215.74, using my vin its a 1999 GTP with the electronic, dual temp control head... should be the same for you, but Id need your vin# to make certain
  20. #20 Re: Are all 2000 GTP AC/Heat Blowers as Bad as Mine?
    Nov 2009
    Grand haven
    After you replace the resistor and everything is working correctly and you get you CABIN filter in you should do this mod too. It will help save the life of you new resistor.
    http://www.grandprixforums.net/water...-fix-6961.html
  1. polished blowers
    By nicksilvergt99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2009, 02:04 AM
  2. I just like this video (not mine)
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 05-28-2009, 11:04 PM
  3. just mine? or all grand prixs?
    By Jakegday in forum General Tech Discussion
    Last Post: 03-25-2009, 11:59 PM
  4. Forgot to do mine also.
    By J_Ferguson in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 06:21 AM
