yea it's pretty easy to take the headlight off, there are two bolts that hold the headlight in place. They are facing up and you just need to unscrew them and then the headlight comes off. Make sure to take off the plugs so you can just remove the whole headlight. You'll know what's going on when you take it off. And if I remember correctly, the passenger side is where the horn is, so if the fog light bulb you need to replace is there, there's no point to remove the headlight, just go from underneath if that's the case.
