Thread: What does the information center, cd player, and the heater controlls have in common
Results 1 to 3 of 3
  1. #1 What does the information center, cd player, and the heater controlls have in common
    SE Level Member shawnz90's Avatar
    Kenosha
    My batterys been draining the last few day over night so i did some snooping around under the hood checking the wire's
    I found that right behing the battery there was a plug and two wires that ran from the plug into the wire harness the colors of the wires were yellow and yellow with a black line or greenish hard to tell it was dark out but the two wires were broked (car ran fine without them no check engine code at all) so i connected the wires and nothing happened no sparks and exc. taped them up and off i went.
    So now about 1hr later me, my girl, and my son are in my car going to a mall thats about 45min's away and 30mins into the drive i smell smoke (electrical smoke-ish smell) but i rushed off the highway and looked under the hood nothing was wrong no fire thank god. Had a pair of plyers so i took out the battery and the wires that i fixed looked fine not burnt up where i taped them at least.
    So i started up the car and it ran fine except the information center, cd player, and heater (the heater buttons lit up but no display) did not work at all. So i drove the car to my parents where i got my camaro out of the grage and droped the car off at the mechanic because im sick of dealing with the problem.
    So does any one have a clue what all 3 have in common a relay a curcit or anything? Just trying to get clues to help out my mechanic.
    With electrical problems he charges by the hr...
  2. #2 Re: What does the information center, cd player, and the heater controlls have in com
    PA
    Your ignition switch is probably going bad. Replace it.
    2001 GSE
  3. #3 Re: What does the information center, cd player, and the heater controlls have in com
    Kenosha
    interesting would that cause the burnt electrical smell?
  1. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  2. Driver Information Center works...but not 2 of the 3 buttons for it
    By michgym170 in forum General Tech Discussion
    Last Post: 09-30-2009, 03:36 PM
  3. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
  4. GM part number for a 5 button Driver Information Center 2004 GTP
    By mnl119 in forum General Tech Discussion
    Last Post: 06-15-2008, 09:54 PM
