Thread: Ap104
Results 1 to 8 of 8
  1. #1 Ap104
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    So tonight i went out and bought some ap104 spark plugs and my motor is basically stock except for a 4'FWI and i was wondering what should i gap them at?
  2. #2 Re: Ap104
    SE Level Member snow99dohc's Avatar
    Rugby ND The Center of Nor. Amer.
    AP104? Did you buy platinums? I just replaced mine the other day. AL104 coppers. 104's arent really needed till 3.5 territory.
    2003 Pontiac Gran Prix GTP-Thrasher CAI, 180 degree t-stat, AL 104's, ZZP/PT Pcm, ZZP Stg 1 HV TB, ZZP headers, 3'' custom catback, magnaflow mufflers, 3.4''
  3. #3 Re: Ap104
    GTX Level Member webracin's Avatar
    Arkansas
    stlmo_gtp, Platinums are not good on a supercharged motor. The bonding agent can give under boost applications and cause the platinum tip to fall off and bounce around the inside of your motor. Also as said, the 104's may be a tad to cold of a plug for your setup. I would jump up one range warmer.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  4. #4 Re: Ap104
    St. Louis
    which are one range closer ? i was told to go with al 605's so that is what i am going for
  5. #5 Re: Ap104
    Banned
    New Port Richey Florida
    But he's going to a 3.4 pulley soon. So the al 104's should not hurt the engine and he'll not need them when he drops to the 3.4
  6. #6 Re: Ap104
    Oklahoma
    I ran a 3.4 pulley on 605's with no issues at all. When I pulled them, to put in a new set, they showed no signs whatsoever of being too hot or too cold. I did, however, run a set of 104's and they did show signs of being too cold of a plug.
    So from a personal experience standpoint, 605's should be fine for you.
  7. #7 Re: Ap104
    St. Louis
    well i ended up going with the 605's a gaped them @.55 i just haven't installed them yet, i'm waiting on my shift kit, some more feedback on the trans fluid, and picking up some oil.... so i can knock everything out at once
  8. #8 Re: Ap104
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    AL 605's are a good choice, even with a 3.4 pulley.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
