Thread: 2000 Malibu 3.1 LIM gasket change help
Results 1 to 8 of 8
  1. #1 2000 Malibu 3.1 LIM gasket change help
    Donating Users Liquifire's Avatar
    Wausau, WI
    Anyone have a parts list of what gaskets or other stuff I may need other than coolant, upper and lower intake manifold gaskets, thermostat gaskets, oil, and oil filter. What else do I need and does anyone know the torque specs for reassembly? Are their any o rings or anything any other gaskets? I put this on a malibu forum, but they are no help so far. I am guessing that this 3.1 is the same as a gp se 3.1 so I thought someone here might have some helpful info for this.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  2. #2 Re: 2000 Malibu 3.1 LIM gasket change help
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I have one taken apart in my garage and it's pretty simple... I am in class right now, when I get home I will take pics and post for you!!
  3. #3 Re: 2000 Malibu 3.1 LIM gasket change help
    Nov 2009
    Tennessee
    One question though.. Have they blown already? Is there coolant in the oil??
  4. #4 Re: 2000 Malibu 3.1 LIM gasket change help
    Wausau, WI
    the coolant is leaking externally only at this point, I want to get to it before the coolant and oil starts to mix. There is none in the oil, and no oil in the coolant. However, it is going through almost a gallon of coolant every ten days or so, and you can smell it quite easily when the motor is running. I can see part of the block is wet on the outside, so it needs to get done soon.
  5. #5 Re: 2000 Malibu 3.1 LIM gasket change help
    Wausau, WI
    I know there are people out there who have worked on the 3.1....come on...admit it.
  6. #6 Re: 2000 Malibu 3.1 LIM gasket change help
    Aug 2008
    KCMO
    http://165.173.35.248:9001/si/home.do
    use this, it should help you. i was gunna do my fiances but i found a guy that did it for 250 instead of 500 so i let him do it
  7. #7 Re: 2000 Malibu 3.1 LIM gasket change help
    GXP Level Member Zef_66's Avatar
    PA
    I used this when I did the wife's:
    LIM and Head Gasket Change Walkthrough/FAQ - GrandAmGT.com Forum
    Everything went fine.
    2001 GSE
  8. #8 Re: 2000 Malibu 3.1 LIM gasket change help
    Nov 2009
    Tennessee
    Sorry got home late last night!!!!
    I did have a 3100 in a 1995 olds Ciera.. It was more or less a paperweight then a motor but that's beside the point.. LOL.. The gaskets blew on me and it poured the coolant in the oil.. It sat for a week then I changed them out.. I guess the crank sat in the coolant enough to wash the oil off and it never really coated good again because I spun the a main and rob bearing about two months later!!! I have it sitting on the engine stand right now if you want to see pics.. I believe the upper manifold is off, have not taken the lower off, didn't want it to leak in the garage because it was sitting sideways while I pulled the crank out..
  1. Trans type in 2000 malibu?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-10-2009, 10:34 PM
  2. 3.4 LIM gasket change
    By Damojo2003 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2009, 03:55 PM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  4. Major false KR on 2000 Malibu 3100
    By Zef_66 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2008, 01:52 PM
