Thread: 2.25" intercooler core and ASCD SD hood? Clearance issues
Results 1 to 20 of 21
  1. #1 2.25" intercooler core and ASCD SD hood? Clearance issues
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I'm looking to upgrade from an SSIC core to a fullsized.
    I currently run a gen V with an adapter plate and LS1 TB. Clearance is tight as it is.
    Does anyone have any experience with trying to fit a fullsized under an ASCD SD hood???
    Here's a pic if it helps.
    For all your 3800 needs:
  2. #2 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Jul 2008
    sumter,south carolina
    your engine and bay is beautiful, who polished the S/C?
    02 GTP with mods 05 GP for DD
  3. #3 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Orange County, NY
    thanks, a guy named Farnsworth is the man to go for polishing and chroming.
    Anyone have any input on a fullsized fitting?
  4. #4 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    from what i hear cradle spacers are the way to do it. Im at the same problem u are my friend. S3 with a Gen V.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  5. #5 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    cradle spacers will cause the same problem as lowering the car too much.
    cut the hood.
  6. #6 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    how would it be the same as lowering the car too much. The spacers are only 5/16".
  7. #7 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Wow. I agree the Polish is awesome!!!
    Lambokit to be built!!!!!
  8. #8 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Quote Originally Posted by bbptech View Post
    do it and find out. the motor/trans does not like to be low.
  9. #9 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Orange County, NY
    Bio is right, the cradle spacers will throw off the geometry of the axles and therefore you'll start to see problems.
    Well, as most of you can tell, the car is a show car, so cutting the hood really isn't something I'm interested in doing that this point to be honest. Doing so would require me to cut the hood, have it glassed, and painted again. I just don't have the funding for such an endeavor right now.
    I'm going to see what my options are when it comes to upgrading my SSIC system... I'll report back with my findings Thanks for the help all!
  10. #10 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    well not to thread jack copgtp, but is cutting the hood seriously the only option for the full sized Gen V IC'ed guys. I paid a G note for my Carbon Fiber SD Hood and dont wanna cut the hood.
    Bio, i wasnt saying your wrong. So hope no hard feelings.
  11. #11 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    nope, i dont have hard feelings. its literally impossible.
  12. #12 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Oct 2008
    Northern Illinois
    Sick engine bay
  13. #13 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Moore, Oklahoma
    It maybe close. My hood is an ASCD HO hood (which is the same thing as yours, minus the rear vents like on the SD. I have the same scoops and Ram Air setup as you) and my 2.00" Intercooler Core fits without any issues and plenty of room. My only issue was that solinoid on the BBV, which I cut off that bracket (like you did) and relocated mine because of the Ram Air ducting. and all was well from there. In fact, I have enough room, I think I could fit a 3" core under my hood without any issues. Course I got a bit more room than you because of the lack of the rear sunk vents.
    Heres what I did before I installed my intercooler. I bought a bunch of Play Doh, and I put a good about at the highest point of the S/C, TB, and the BBV... I closed the hood and measure the heights in those key areas, I repeated this test a couple times to ensure no errors. It worked flawless for me and I knew I had room from the begining, minus that BBV solinoid bracket of course which was an easy fix.
    Try this method out and see where your at. You'll be close, but i'll bet it'll work. You already have one thing going for you, you have fuel rails which increases clearence another half inch-inch easy.
    Shawn W. Larsen
  14. #14 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Moore, Oklahoma
    BTW, here is a crappy pic, you can kinda see the underside of the hood...
    Shawn W. Larsen
  15. #15 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Moore, Oklahoma
    Quote Originally Posted by copgtp View Post
    BTW, I noticed you boost solinoid that used to be on the BBV is completely gone, did you completely remove it? What codes need to be deleted or what PCM work needed to be done? I've been really meaning to get rid of mine and my EVAP too...
    Shawn W. Larsen
  16. #16 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Banned - Busted For Scamming
    Feb 2009
    Im thinking he might be going the custom route with a 1.75" core cause of the clearance issue.
  17. #17 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Quote Originally Posted by Iron Indian View Post
    I was wondering the same thing...
  18. #18 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Moore, Oklahoma
    TTT
    Shawn W. Larsen
  19. #19 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Charles City, IA
    I am pretty sure when you pull the solenoid you just have to change the fueling in the tune so it does not pull any fuel before a shift ect. When the bbv would pull boost.
    SMGPFC Two Nipple General
  20. #20 Re: 2.25" intercooler core and ASCD SD hood? Clearance issues
    Moore, Oklahoma
    TTT
    Shawn W. Larsen
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
