Thread: PCM tune
Results 1 to 3 of 3
  1. #1 PCM tune
    SE Level Member Pontiac Warrior's Avatar
    Hudsonville
    I feel stupid asking this but could someone explain to me what a PCM tune is? I have read about custom tunning and "canned Tunes", is a canned tune a predone thing or somthin that has to be installed at a shop? Any info would be awsome Thanks guys!
    Pontiac Warrior
  2. #2 Re: PCM tune
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  3. #3 Re: PCM tune
    Jan 1970
    Maquoketa, Iowa
    Basically there are 2 programs out there to tune OUR gm 3800 cars right now. One of those programs called powrtuner is no longer sold, the other one is hptuners. Basically, the vendor uses one of these programs to change values/files in the pcm that will hopefully make the car run better. For instance, sometimes when installing a cold air intake or headers/flow mods, the car will run leaner. So they change a couple of things to force the car to add more fuel at the right times. They might also change the line pressures or shifts to firm up the shifts in the transmission or shift at higher rpms. There are a lot of things that you can change. Since every car is different and its hard to get something that will work well on all cars, they call it a canned tune from the vendor. A custom tune would be created by someone who physically scans the specific car and changes the tune according to the results of the scan. It is a more accurate way of tuning the car to be able to perform well.
  1. Who can Tune?
    By joesforspeed in forum Turbo
    Last Post: 06-26-2009, 02:28 PM
  2. ECM tune
    By dsponder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2009, 05:05 PM
  3. Need a tune up!!!
    By 52 picup in forum General Tech Discussion
    Last Post: 10-19-2008, 12:26 PM
  4. Anyone want to tune near MD?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-13-2008, 10:00 AM
  5. Tune Up
    By bcrosby51 in forum General Tech Discussion
    Last Post: 08-20-2008, 03:19 PM
