Thread: i'm a dumbass...but please help me anyway.
Results 1 to 15 of 15
  1. #1 Re: i'm a dumbass...but please help me anyway.
    Troy OH
    Quote Originally Posted by rynoman03 View Post
    The tank is a bit more that 12 Gallons man. I think its closer to 17-18. I know i've put over 13 gallons in before. I think the last time i filled up it was over 30 bux. But I use 91 octane.
    As for your car replace the fuel filter first thing, then go from there. Your pump could be sol but if it is running its hard telling. It could be that you even have some clogged injectors.
    i must be special then. my gauge will be as close to empty as i care to get and i've never put more than 11.5 gallons in it.
  2. #2 Re: i'm a dumbass...but please help me anyway.
    GTX Level Member cerick08GP's Avatar
    Lmao…
    You guys can crunch numbers all day, but it still doesn’t change anything. If you want to spend less money on “filling up” then replace your gas tank with a fuel cell, and then brag to your friends how it only costs you $10 to fill up!
    Anyway jayetune, to answer your mpg question. Once your car idles/runs properly there isn’t much you can do to the car increase mpg except change the plugs, and keep an eye on tire pressure. I personally run 33 psi in the winter and 37 psi in the summer, running these pressures I picked up about 1 mpg. A couple things to consider would be to replaced your O2 sensor and change to Dexron 6 at your next tranny pan drop. Anyway, mpg comes up on this site daily, and the biggest factor for 98% of the people is how they drive. A well maintained stock GP gets amazing gas mileage; you can’t get blood out of a turnip.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Dumbass Brake question.....
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2008, 12:24 AM
