Thread: Melted Vacuum Sensor <_<
Results 1 to 10 of 10
  1. #1 Melted Vacuum Sensor <_<
    Wichita
    The Boost Gauge in my DIC wasn't working right. The bars would stay lit up. I checked for vacuum leaks & found a loose sensor melted on top of my rear headers.
    Anyone have one of these they don't need? Otherwise it looks like it's Pontiac or the junkyard.
  2. #2 Re: Melted Vacuum Sensor <_<
    Charles City, IA
    That is your map sensor. I don't have one tho...
    SMGPFC Two Nipple General
  3. #3 Re: Melted Vacuum Sensor <_<
    Wichita
    Ah MAP sensor. now I know what to ask for thx
  4. #4 Re: Melted Vacuum Sensor <_<
    Charles City, IA
    No problem.
  5. #5 Re: Melted Vacuum Sensor <_<
    Wichita
    Is the MAP sensor the same for SE, GT & GTP?
  6. #6 Re: Melted Vacuum Sensor <_<
    Charles City, IA
    no you need a gtp one
  7. #7 Re: Melted Vacuum Sensor <_<
    Wichita
    Found one for sale here on the forums.
  8. #8 Re: Melted Vacuum Sensor <_<
    SE Level Member trickytransam's Avatar
    Michigan
    Why did it melt? Missing a heat shield?
    Or is it common for those to have a melt down (how is this possible with only 5V reference signal)?
  9. #9 Re: Melted Vacuum Sensor <_<
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    he said it right here
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  10. #10 Re: Melted Vacuum Sensor <_<
    Wichita
    I sure did.
  1. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
  2. sparkplug melted
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 04-12-2009, 05:22 PM
  3. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
  4. vacuum at idle?
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 06:37 PM
