Thread: starts and dies
Results 1 to 13 of 13
  1. #1 starts and dies
    NW Indiana
    I went to start my car this morning and the car will run for a couple of seconds and then die. It will do this everytime i try to start it. The security light isnt flashing so i know its seeing the key and i hear the fuel pump cycling on. We did have alot of fog last night and im wondering if its something to do with the condensation. Any thoughts?
  2. #2 Re: starts and dies
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    What year car do you have?
    For all your 3800 needs:
  3. #3 Re: starts and dies
    SE Level Member CityStarz's Avatar
    Nov 2009
    pittsburgh PA
    most likely low fuel pressure
    L36|Topswap|3.25|NIC cam|JP Double|Comp 105s|SLP Headers|Full stainless 3" to 2.5" Y|Fully Ported Blower|ST2 TB|FWI|PT|LC-1
  4. #4 Re: starts and dies
    Orange County, NY
    Agreed, just wanted to see what year he was dealing with. I'd suggest the ol' fuel pump fuse trick.
  5. #5 Re: starts and dies
    NW Indiana
    I actually already have those wires for the fuel pump bypassed and the car is a 2000 gtp and a new maf sensor
  6. #6 Re: starts and dies
    Nov 2009
    Sallisaw,Ok
    When you turn your key on,does the security light come on and prove out?
    This will verify the security light is working.
    Try cycling your key to the on position from off several times.
    Hold it on the "on" position for just a few seconds each time.
    After about 5 times of doing this attempt to start it.
    Does it start and run fine?
  7. #7 Re: starts and dies
    NW Indiana
    ill try that out for sure. The security light does go out though.
  8. #8 Re: starts and dies
    Nov 2009
    Festus MO
    im having the same exact problem 2001 gp 3.1 start it will run like 3 seconds and will die if you try and start right back up(with out turning off) if wont run again but if you shut off and try again it will run 3 seconds. Only thing that seems to make it run is if I unhook the postive battery cable and turn the key for 60 seconds(without the postive cable hooked up it won't start and key gets stuck in the ingintion) and then hook back up the postive cable then turn key off and it will start and run just fine. it works for a week or so but the problem comes back. seems like coming back sooner and sooner now. and i'm getting tired of resetting my stereo lol. NO security light flashing or staying on(just the one sec when starting car then never comes back on) I have put a new battery new map senor new IAC, I am just stupmed. I am sorry did not mean to high jack thread but dont wanna post the same thing over and over again. Would this mean the PCM needs reflashed or? any idea's? thanks mike
    ALSO i have tried both my keys, tried unlocking with both key fabs, tried unlocking with keys. my car has the viper keyless entry i have no clue if thats stock or not lol
    ALSO i have a scanner from orileys and NO codes are comming up
    Last edited by mschillingii; 11-26-2009 at 03:51 AM. Reason: dur i for got somethings
  9. #9 Re: starts and dies
    Nov 2009
    Sallisaw,Ok
    Quote Originally Posted by mschillingii View Post
    And i'm guessing you haven't tried to do what I told him to try and do yet either.
    Cars don't just "need" a PCM reflash.
    When a PCM goes bad,it doesn't just "go bad" and need reflashed.
    It goes bad on a single wire-reflashes are for driveability issues due to calibration.
  10. #10 Re: starts and dies
    Nov 2009
    Festus MO
    Quote Originally Posted by DefEddie View Post
    i figured that was about the same as what i was doin with the battery cable and key next time it dont start(mostlikely later today) i will try that and let you know what it does
    ALSO with mine the security light goes out when the ses light does
  11. #11 Re: starts and dies
    Nov 2009
    Festus MO
    NOPE did nothing still had to disconect the postive an key trick to get it started any idea's?
  12. #12 Re: starts and dies
    Nov 2009
    Sallisaw,Ok
    Take it to a dealer,your unequipped to deal with it.
    (i'm assuming you don't have a tech2,datalogger,multimeter etc...)
  13. #13 Re: starts and dies
    NW Indiana
    Just for the hell of it i went out this morning and rocked my car back and forth a few times, couldnt believe the car started, im thinking maybe a fuel pump issue or maybe bad gas? I use premium all the time(sc)
  1. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  2. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  3. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
  4. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
  5. car starts, runs for a second, then dies
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 11:34 AM
