Thread: will this be enough mods?
Results 1 to 20 of 22
  1. #1 will this be enough mods?
    ontario
    I have a 99 GTP which is pretty much stock. I have NGK TR55 plugs with NGK Wires. My supercharger pulley is banged up on one side due to previous owners mechanic when changing the seal in the supercharger.
    So I need to change the pulley and was thinking on going down to a 3.4". This is what I was planning on doing as well, let me know if this is enough.
    K&N drop in intake filter (don't really wanna change the stock set-up)
    180 thermostat
    New Goodyear Gator belt
    Intense PCM
    Autolite 104 plugs
    U-bend delete if I have to
    and obviously the 3.4" pulley
    With that being said, is that enough to run a 3.4" pulley? It's only my summer car as I live in Ontario and store her for the winter.
    Thanks Guys!
  2. #2 Re: will this be enough monds?
    SE Level Member Feather Head's Avatar
    Wausau
    Go and read this it will give you all the information to safely drop pulleys on your car http://www.grandprixforums.net/f81/s...car-17482.html
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  3. #3 Re: will this be enough monds?
    Joliet, IL
    ^^x2 and that list is no where near enough for that pulley...
    do this....
    3.4
    tune
    headers
    tr6 ngk plugs
    and get rid of the stock intake esp. if you have the double 90* one
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: will this be enough monds?
    ontario
    really...reason why i ask is because when you go to intesnse racing's website, there level 1 performance kit includes the 3.4" pulley, thermostat, pcm, belt, plugs and cai intake. so according to their site it should be good. why would they say that then?
    thanks
  5. #5 Re: will this be enough monds?
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Quote Originally Posted by 19GTP99 View Post
    thanks
    It's cheap to mod a car that way. The exhaust mods are expensive. A set of good headers alone cost as much as all those mods put together. Maybe they just want to sell parts? I don't know. But from what I've learned, you need headers and dp on top of those mods to run a 3.4. That's why my 3.4 is still in the box! waiting on exhaust mods! LOL
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  6. #6 Re: will this be enough monds?
    GXP Level Member
    Theworld
    thanks
    You can run a 3.4 with that setup, it will most likely have knock. You might be able to get away with it for a while, but it will eventually hurt the car.
    If you got the money, buy headers and a full exhaust kit and you'll be fine running a 3.4 (And cai,plugs,ect)
  7. #7 Re: will this be enough mods?
    on about 10* of timing advance you might be able to run that.
  8. #8 Re: will this be enough mods?
    Banned - Busted For Scamming
    Feb 2009
    My 3.4 goes like hell now after my box tune. Check out mods in sig.
  9. #9 Re: will this be enough mods?
    FLOW MODZZZZZZ.
    All those sites tell you is what they want you to run...it isn't safe. Go read that thread I wrote. THEN...come back with questions.
  10. #10 Re: will this be enough mods?
    ontario
    Well I guess I will order a stock pulley then. I was looking forward to a little more power, but I will take all of your advice. I will do the 180 thermostat, drop in air filter, Intense pcm and autolite 104 plugs for now. I need to buy a winter car so I don't have the money to buy headers and an exhaust system unfortunately. Should I take out the U-bend anyway, or leave it alone? I appreciate all the help guys.
  11. #11 Re: will this be enough mods?
    Nov 2009
    Portsmouth, OH
    This is the write-up that bluegtp91 is referring to that he wrote. Lots of good info! I got it bookmarked.lol
  12. #12 Re: will this be enough mods?
    Feb 2009
    If youre getting headers later it wouldnt matter as the downpipe for the headers deletes that.
  13. #13 Re: will this be enough mods?
    ontario
    I doubt I will be getting headers. I would love to, but way too many bills and a wedding in the future.
  14. #14 Re: will this be enough mods?
    Nov 2009
    Portsmouth, OH
    Cars are more loyal than a wife! LOL. Sorry that was uncalled for.
  15. #15 Re: will this be enough mods?
    Donating Users
    central ohio
    i put on dp with high flow cat, glass pack in place of resonator, cai. autolite colder plugs. 93 octane, 180 thermostat, runs like a scalded dog. surprised me.( i have a 3800 perf ecm and modular 3.4 pully in trunk) due to all the good advice on this forum i am going to make sure before going furthur, read up as much as you can, dont blow your engine with kr. thanks to all forum members who have been through this the painful way for all their advice. dont rush it, i;m kicking arse now and lovin it.
  16. #16 Re: will this be enough mods?
    Jan 2009
    Tallahassee, FL
    You can get a set of headers for $350 or so new, if you gut out the airbox with the K&N it's a good start, and the rest of the stuff you have listed will let you run a 3.4" pulley.
    Also these stage X kits that sites list are never correct really for what you really have to properly run for a given setup.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #17 Re: will this be enough mods?
    Donating Users
    central ohio
    whoops i meant pcm. 98 gtp, cai,plugs,180,3 inch dp,ubend delete
  18. #18 Re: will this be enough mods?
    Joliet, IL
    dont run AL104's on a stock pulley your only hurting your idle and MPG...for no reason.
    00 Silvermist GTP
  19. #19 Re: will this be enough mods?
    Hurting your idle? is that?
  20. #20 Re: will this be enough mods?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    And honestly, if u slapped that pulley on their, it would probably make ur car run worse. Honestly, its not the most important thing bro. Just a little at a time. That's what I did. And if u can't afford headers look into a plog setup from zzp
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
