Thread: Where is my oil going??
Results 1 to 6 of 6
  1. #1 Where is my oil going??
    North Jersey
    I hope this is the right section. I have an Implala w/the 3.8 engine. I have to add a quart of oil every 3k miles. There are no puddles under the car and I had it on a lift last week and it is bone dry. So I assume it is burning it, but I am fairly sure every 3K is not normal.
    Is there somewhere else I should be looking?
  2. #2 Re: Where is my oil going??
    Jul 2008
    sumter,south carolina
    could be a valve cover gaket... mine had a bad leak with no puddle, leaked onto exhaust manifold and burned off.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Where is my oil going??
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    if it was still under warranty, and you took it to the dealership complaining about this, they would tell you nothing is wrong, and that a quart every 3000 miles is perfectly acceptable.
    when i first got my grand prix it was using about a quart every oil change. i switched oils to valvoline maxlife and it hasnt used a drop since
    ALOT of GM engines lose oil, and alot of them lose a hell of alot more then yours is losing
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Where is my oil going??
    GTX Level Member cerick08GP's Avatar
    Well, like Jake indicated. A quart every 3K isn’t alarming, but it would concern me as well.
    My advice to you is change to a “high mileage” oil, they have extra seal conditioners and minimize burn off.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Where is my oil going??
    Charles City, IA
    Check your coolant to see if it has oil in it.
    SMGPFC Two Nipple General
  6. #6 Re: Where is my oil going??
oil
