Thread: Steering wheel shaking a little after tire rotation
Results 1 to 14 of 14
  1. #1 Re: Steering wheel shaking a little after tire rotation
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Quote Originally Posted by JDCMoney View Post
    after rereading your post i noticed you swapped your fronts left to right and right to left and the same for the rears...
    Make sure you dont have rotational tires....
    It may sound stupid.... but what do you mean with "rotational tires"?
  2. #2 Re: Steering wheel shaking a little after tire rotation
    GT Level Member BackInBlack's Avatar
    Vermont
    Quote Originally Posted by Haulero View Post
    Rotational tires are usually have a performance tread that is designed to rotate in one direction only. Look for an obvious arrow next to the word "rotation" in the sidewall.
    The GPs are long gone...
  3. #3 Re: Steering wheel shaking a little after tire rotation
    Wooster, Ohio
    Quote Originally Posted by BackInBlack View Post
    actually called "directional" tires as in they only go one direction, like Asymetrical tires that have one side ment to face out. Your problem is you crossed your tires and you have a shake in a tire/wheel. Thats it, no questions asked. I've done this for 7 years and see it everyday. A proper automotive rotate with non directional tires is front to rear, rears swapped sides to front. Shops put a bad balanced or bent wheel assembly on the r/r of your car so when you leave the shop you can't feel it. Once you rotate that one ends up on the l/f and you feel it. Swap those 2 back and it will more then likely be gone or spend the $15, go to a shop and have them balanced
  1. Official wheel/tire thread
    By Boostd1 in forum Tires & Wheels
    Last Post: 01-02-2010, 03:17 PM
  2. Shaking in front left tire
    By InfidelRebel in forum General Tech Discussion
    Last Post: 09-27-2009, 07:58 AM
  3. Lakeshore Wheel & Tire?
    By Sheepdog in forum General Tech Discussion
    Last Post: 08-04-2009, 01:13 AM
  4. Tire Rotation by Idiots!
    By TFBuckeye in forum The Rant Forum
    Last Post: 01-04-2009, 05:40 PM
  5. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
