it drove fine to walmart turned left in to a parking spot went in came out 10 min later and could not turn left, the tires are evenly worn, im thinking it is the rack, does anyone know if a 97 will work
Hmm normally if the rack was going to fail the problem would continuously occur, did you check the tie rods? if the grease is gone in the joints and are locking up when you turn then that could be causing the issue, as for a 97 im not sure but is possible since its 97 to 2003 most parts are swappable. I would try to lean more 99+ rack to be safe if a rack is needed.
