Thread: Anyone use The voltage booster/Alt rewire kits?
Results 1 to 5 of 5
  1. #1 Anyone use The voltage booster/Alt rewire kits?
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    Anyone have any experience using the alternator voltage booster and the alternator rewire kit that ZZP sells? They're cheap so I was lookin at pickin em up but I wanted to check and see if its just a gimmick or if they actually do what they say. Thanks all.
    Voltage Booster: ZZ Performance
    Alternator Rewire: ZZ Performance
  2. #2 Re: Anyone use The voltage booster/Alt rewire kits?
    I think their dumb...but to each their own...
  3. #3 Re: Anyone use The voltage booster/Alt rewire kits?
    voltage booster thing is a waste.
    the alternator rewire just hooks the alternator straight up to the positive battery post on the fuse block and actually keeps the voltage more consistent. i had one on my car.
  4. #4 Re: Anyone use The voltage booster/Alt rewire kits?
    I have a voltage booster. It's the full blown casper one that bumps you up when the throttle is over 70%. Used for a little while and decided not to stick with it.
    You could definately see a 2-5 volt increase in the headlights etc. If you notice a large voltage drop off at WOT, then it has merit. Most likely, it's something you won't need.
  5. #5 Re: Anyone use The voltage booster/Alt rewire kits?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You can do them both yourself on the cheap. I would not do the booster, personally. The alternator rewire should be done with a circuit breaker in the line to avoid a potentially ugly situation if something goes wrong.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. Alternator Voltage Booster question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2009, 07:23 AM
  2. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
  3. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
