Unless your AC compressor is bad...I'd probably mention that there's not enough of a difference to remove it. If you are removing a good compressor, please pm me. I'd be interested in buying and wouldn't need shipping.
Hey guys! I used the search function and found that it appears the only option I have to bypass the a/c is to get the a/c bypass pulley.
My girlfriend has a 99 GTP and the a/c clutch is apparently going out, a loud noise coming from that area and Is sounds like the same thing when my a/c clutch was going out on my Camaro. She was told it would be about $900 to fix it because they need to replace the compressor, etc. She's getting a new car In December and giving me the GTP since I totaled my truck and I don't need A/C so I'm just going to do the A/C bypass pulley. It sounds pretty simple to do and cheap also!
Now that i'll be taking over the GTP, i'll be using this forum a lot. I was on LS1tech when I had my Camaro and found the forums to be very helpful.
