Thread: Common Problems??
Results 1 to 8 of 8
jayrayllc Common Problems?? 10-27-2009, 05:02 PM
Feather Head Re: Common Problems?? 10-27-2009, 05:46 PM
TheOtherNick Re: Common Problems?? 10-27-2009, 05:47 PM
mxthunder Re: Common Problems?? 10-27-2009, 06:25 PM
techweenie Re: Common Problems?? 11-01-2009, 02:20 AM
99prixgt Re: Common Problems?? 11-01-2009, 02:43 AM
BwolfGT Re: Common Problems?? 11-01-2009, 03:43 AM
techweenie Re: Common Problems?? 11-01-2009, 09:49 AM
  1. #1 Common Problems??
    lee's summit, mo
    hey all,
    new here, just said hello in the intro forum...but on to my question.
    i dont have a gp just yet, but i am looking. what are some common problems that i need to be mindful of in my search for a 97-03 grand prix gt. i dont think i want the supercharged version because of gas mileage and the fact that you have to run premium in it. but if im off on that, let me know as well. just had a baby so...it has to be a four door, unfortunately.
    i grew up working on everything that was broke, so i do know from experience that everything has its weak spots...so let me hear of them.
    thanks to all who chime in!!
  2. #2 Re: Common Problems??
    SE Level Member Feather Head's Avatar
    Wausau
    The transmission is the most common thing to go in a GP and from what i have read the GTP and GT get almost the same gas millage
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  3. #3 Re: Common Problems??
    Charles City, IA
    Get a gtp. I get 29 on the high way with mine. This to watch out for are the blower motor resistor and the lim gaskets.
    SMGPFC Two Nipple General
  4. #4 Re: Common Problems??
    SE Level Member mxthunder's Avatar
    NE Ohio
    not to jack this thread, but is the blower motor resister hard to change?
    Autolite 103 plugs, PRJ 8 gauge wires, 160* drilled tstat, Digital Horse Power Stage 1 PCM, Voltage booster harness, 3.25" pully, ZZP S.S. IC, Desert Fox tranny cooler/Thrasher shift kit, Wizair CAI, SLP headers/full system wrapped & coated, 3 gauge pods: A/F, Boost (16.5 lbs), comp G. 17" 04 GTP rims
  5. #5 Re: Common Problems??
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    I am also looking at buying a Grand Prix and would like to know common issues. I have already noticed the blower motor resistor is a common problem since all but one of them I've driven so far had that problem. I have been taking each of them to a repair shop for a free inspection and every one so far has been reported to have oil leaks around the oil pan and various other areas. Is that anything to worry about? I had an 03 S10 with the 4.3 that always had a oil-soaked oil pan and it ran like new so for now I'm not too worried about that. Currently I have my heart set on a GTP sedan with a clean history. Its got some clunking up front when going over bumps and it feels like it misses when you give it a lot of gas. The front struts are brand new so the current owner's mechanic told him it was the brake caliper brackets causing the clunking. I dunno if I believe that, but I can't imagine it being anything serious. Its got 133k miles so I'm hoping a solid tune-up will fix the missing. I've never driven a supercharged car before so I'm not familiar with the spark retard and stuff like that.
  6. #6 Re: Common Problems??
    Jersey
    Most common problem is loosing O/D or the 4th clutch.
    97 gt's have a weak vacuum controlled transmission. 03's have little changes done to the transmission, they come with a hardened 4th clutch.
    16' wrx sti- stock
  7. #7 Re: Common Problems??
    Oct 2008
    Northern Illinois
    These car's are pretty solid, most common problems are vac leaks (cheap/easy fixes), sensors (again, cheap/easy), and the 4th gear on the transmission.
    Get the GTP, yeah you have to run 93, but it's worth it and the gas mileage is the same as the GT.
  8. #8 Re: Common Problems??
    Nov 2009
    Grand Blanc, MI
    If a GTP is run on regular gas could it cause the missing I felt under heavy acceleration? The owner if foreign and I don't know if he's aware it requires premium gas.
  1. Common Acronyms
    By TyroElite in forum General Tech Discussion
    Last Post: 11-07-2019, 07:51 PM
  2. Common Problems?
    By deadmittens in forum General Tech Discussion
    Last Post: 09-28-2009, 12:31 PM
  3. Common Oil Leaks?
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2009, 08:09 PM
  4. Is this common?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2009, 02:05 PM
  5. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
