I am not sure it is the BCM.. but with the fan, Daytime running lights, Driver information crap, and fan all starting at the same time, looking at the wiring diagram in the Chilton's manual, and looking at other entries in the thread I thought it was the only answer..
Now I am not sure... CRAP...
It could be the ignition switch I guess, She has had the key stuck problem also, which I just learned in the forum that I can yank out a solenoid to correct that issue. I am not sure if they could be related.
Not sure where to start now.. Replacing the BCM seems easier now, assuming there is no programming which I saw was required somewhere, not sure if it is just for the key fobs or if the BCM is replaced..
I am freaking lost again...
Ugg...
