Thread: 97 GTP vs other years?
Results 1 to 17 of 17
  1. #1 97 GTP vs other years?
    Wooster, Ohio
    i did search a little and read some stickys and i cant find any to the point info on this, i just got a 97 GTP, and i'm aware the PCM is different then other years, but why, and what else is not interchangable. I thought all this body style were generally the same
  2. #2 Re: 97 GTP vs other years?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    They updated PCM's in late 97 I believe. Yours has 4 connectors while the 98-03 have just two.
    Another thing is the transmission. Yours is vacuum controlled while 98+ are not.
    Throttle body is different as well in 97 and 98. They have a sealed MAF sensor while the 99+ is opened.
    Trying to think of other things. I know the DIC is different, like 98+ has trac control and yours doesn't (if I recall)
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  3. #3 Re: 97 GTP vs other years?
    the 97 GTP has the 4t65e, so its not vacuum controlled. only 97 SE and GT came with the vacuum one.
  4. #4 Re: 97 GTP vs other years?
    Moore, Oklahoma
    Yep and IIRC (trannyman would have to comfirm this) later year SE/GTs in 97 got the 4T65 instead of the 4T60 (vac controlled) tranny.
    GTP has always has the 4T65-HD in the 97-03 GPs...
    Shawn W. Larsen
  5. #5 Re: 97 GTP vs other years?
    SE Level Member 97gpGTP's Avatar
    Nov 2009
    Manitowoc, Wisconsin
    Quote Originally Posted by Iron Indian View Post
    97 was still vacuum controlled with the 4T65-HD. 98+ had the 4T65-EHD (electric).
    GenV | 3.2 MPS | XP Cam | SpeedDaddy Headers | LS6 Springs | N* TB | JMB FWI | ZZP Shift Kit | ZZP Poly Bushings | GMPP front sway bar| Eibach springs
  6. #6 Re: 97 GTP vs other years?
    Nov 2008
    Quote Originally Posted by 97gpGTP View Post
    hah! I knew it!
  7. #7 Re: 97 GTP vs other years?
    Nov 2009
    Quote Originally Posted by ninnyGTP View Post
    hah! I knew it!
    Now we can all sleep comfortably at night...
  8. #8 Re: 97 GTP vs other years?
    PA
    Wait, what?
    So you are telling me that my 97 GTP has a vacuum controlled tranny!?!?
    And here I have been trying to tune it with my PT all this time!
    2001 GSE
  9. #9 Re: 97 GTP vs other years?
    Feb 2008
    ALL 97-03 GTP's have an electronically-controlled 4T65E-HD!
    To answer the OP: Just about everything is interchangeable. Some parts may require a little bit of modification.
    The washer fluid reservoir is in a different location on '97 and '98 than the '99+ making some aftermarket intakes un-usable. This can be fixed by getting and installing a newer reservoir and removing the old one.
    The air box in '97 and '98 is also VERY inefficient compared to the newer ones. (This goes back to the coolant reservoir issue, too)
    The PCM is physically larger than the '98 and newer ones, but does have the same plug type.
    You do not have traction control of any kind (you can consider that a blessing if you are like me and prefer not to have it anyway).
    The throttle body for '97 and '98 is a little different and uses a different style MAF. The '99+ ones flow a little better in stock form. (However, a ported '97-'98 TB can outflow even a modified '99+ TB.)
  10. #10 Re: 97 GTP vs other years?
    Nov 2009
    Also the supercharger has a different vacuum routing, evap system is different, the airbox, abs pump, pcm, washer & coolant bottle locations, HVAC color is green, DIC doesn't have tc as previously stated, a lot of 97 only had a manual lumbar (I got lucky and have power :P ), most 97 have a full antenna instead of the window antenna, the vacuum controlled trans as previously stated, tb...that's all I can think of atm...
  11. #11 Re: 97 GTP vs other years?
    Nov 2008
    Waterloo, Iowa
    I don't think lumbar made a difference, my 98 has manual lumbar...
  12. #12 Re: 97 GTP vs other years?
    Wooster, Ohio
    I've got the regular antenna, which is missing btw. and power lumbar also! Go us!
  13. #13 Re: 97 GTP vs other years?
    Nov 2008
    haha def
  14. #14 Re: 97 GTP vs other years?
    Wooster, Ohio
    thanks for all the info, i'm glad to finally get one way on the trans issue lol, which i checked for myself on that to make sure, I was nearly positive they were not vacuum. Thanks and this really does help in my junkyard hunting that will be taking place oh so frequently in the next few weeks for this turd
  15. #15 Re: 97 GTP vs other years?
    Wooster, Ohio
    i've got power on my 97
  16. #16 Re: 97 GTP vs other years?
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by Pittman06 View Post
    i hate you. =[
    my cheap ass lumbar knob is one of those ones that is broken when you get the car... it still works, it just hangs out the seat....
  17. #17 Re: 97 GTP vs other years?
    Wooster, Ohio
    Its very nice, and one of the few things that work properly in my bucket lol
  1. 22, wanted a GTP for 5 years
    By mxthunder in forum Introductions/Noob Questions
    Last Post: 10-26-2009, 12:40 AM
  2. We Will Never Forget: OKC 14 Years
    By Toofastgs in forum Off Topic Discussion
    Last Post: 04-19-2009, 10:04 PM
  3. New Years Resolutions
    By 98GP in forum Off Topic Discussion
    Last Post: 01-03-2008, 01:46 PM
  4. Happy New Years!
    By BabyBlue in forum Off Topic Discussion
    Last Post: 01-01-2008, 02:27 AM
  5. Happy New Years Everyone !
    By bayareagtp in forum Off Topic Discussion
    Last Post: 12-29-2007, 03:39 AM
