Thread: 2 tech questions
Results 1 to 2 of 2
  1. #1 2 tech questions
    SE Level Member mxthunder's Avatar
    NE Ohio
    Discovering all the querks with my new car.
    1. At WOT, sometimes, not always, the display thing where it says MPG, etc will totally blank out, along with the radio. The display does it more often though. I have some type of voltage booster harness on this car, does that have anything to do with it?
    2. Should I be able to hear my IC pump running with the key on, but the engine off? It is a ZZP short stack unit, with a flojet pump.
    Thanks!
  2. #2 Re: 2 tech questions
    the voltage booster cable should have nothing to do with it unless youre seeing 15V+ when youre going WOT, which is then why the accessories go out. they cant handle high voltage like that and go into a fail safe mode. hook up a volt gauge and figure it out.
    the IC pump should be heard with the key on and the engine off (in run position).
  1. newbie looking for tech info
    By roy in forum Introductions/Noob Questions
    Last Post: 10-31-2010, 04:46 AM
  2. Meguiars Tech Wax Ftw
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 08-16-2009, 07:56 AM
  3. Tech Question
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-22-2009, 03:12 AM
  4. Suspension Tech
    By GS-SC in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 02:35 PM
