Originally Posted by BlackFlag most used ebcms have to be "flashed" to your specific car. Im hoping for a hub. I shall inspect this weekend that dtc means the desired torque signal PWM duty cycle is less then 5% or greater then 95% or desired torque signal is not received by pcm. im thinkin your ebcm took a dump or you need to check the serial data circuit. This has no relevance to a hub
Forum Rules
