Thread: Turn Signal Issues
Results 1 to 4 of 4
  1. #1 Turn Signal Issues
    GTX Level Member nikkigpgt00's Avatar
    MI
    I found this morning that my front right blinker is out, I didnt realize it until I was driving to work and the blinker was blinking super fast. I checked it out when I got to work and for sure it was out. Now the back one still blinks, but really fast. Does this mean its about to go as well? Also do you think I have a short or just bad timing with bulbs???
    My front left corner lense keeps getting wet inside, and I just replaced it. I have to look into why this is happening? I think this is probably why the turn signal bulb and the little amber bulb are both out. Anyone have a take on any of these issues? I have only had the care for a month now.
  2. #2 Re: Turn Signal Issues
    Wausau, WI
    it blinks really fast when one of the other ones go out. If you replace the burned out one the others should return to normal. you should not be getting fluid into the housing on the front by the bulbs. The seal is most likely bad, and needs to be replaced. I have heard of drilling pinholes in the bottom of it(out of site) to allow the moisture to escape. Good luck.
  3. #3 Re: Turn Signal Issues
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    ^ x2
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  4. #4 Re: Turn Signal Issues
    Sep 2016
    Saco
    Had same issue, except amber bulb in foglight lights up but doesn't flash. right front turn light is lit but when you turn on blinker the rear clicks at double speed and front doesn't do anything? Any suggestions here?
  1. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  2. Turn signal switch... bad?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-23-2009, 08:20 PM
  3. Turn signal switch... bad?
    Last Post: 09-18-2009, 11:17 PM
  4. Turn signal Issues
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 10:39 AM
  5. Turn Signal on Solid
    By coolken84 in forum General Tech Discussion
    Last Post: 08-31-2008, 01:39 AM
