Thread: CV Joints are going i believe
Results 1 to 20 of 23
  1. #1 CV Joints are going i believe
    Aug 2008
    Long Island, New York
    Pretty sure my passenger side cv joint is going. I have the infamous green grease on the control arm, and under the hood and its making an annoying squeak every now and then. So basically what should i do? buy new axles? or do i need to buy just new joints or something? if someone could gimme a link to what i need to buy it would be appreciated! and also how hard of a job would it be to do?
  2. #2 Re: CV Joints are going i believe
    Rock Auto has awesome ones...cheap too...that is where I bought mine after my stockers took a crap at 80K or whatever.
  3. #3 Re: CV Joints are going i believe
    Aug 2008
    cool, ill check it out. any advice on the install?
  4. #4 Re: CV Joints are going i believe
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by 2000GTP View Post
    To pop the shaft out of the tranny it takes some finangling. Sometimes just use a crowbar to wedge in and snap it out of there, or wedge in and have someone else tap on the axle with a hammer. Most of the time it just takes a sudden jerk at the right time to get it out. If you do it by hand most of the time you end up a lil bloody.
  5. #5 Re: CV Joints are going i believe
    Joliet, IL
    get the big nut off the axle....
    seperate the control arm from the wheel hub with a pickle fork....
    pull axle out of the wheel hub by pushing it back and manuvering it out of the back of the hub.
    get under the car and get a big socket extension....place the extension on the big piece of the axle closest to the trans...you wanna have the extension facing the wheel hub (outward from the trans) use a hammer and bang the axle outward it will tap out, some are harder than others (its held in with a snap ring)....or use a slide hammer (rent from auto store, much easier)...tranny fluid may spill out a lil bit this is ok.
    clean up grease and do it all again in reverse order (make sure to pop the axle in you will hear the ring snap.)
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  6. #6 Re: CV Joints are going i believe
    Aug 2008
    ok, cool i have a pretty good idea of it now. and i only need to buy the new boot, clamps, bands and grease right? or are there any other parts that i need?
  7. #7 Re: CV Joints are going i believe
    Wausau, WI
    yes, but you will have to pull the shaft out to do that as well, I believe. This is also assuming that your bearings/joints are all OK....which you better inspect before installing new boot/grease
  8. #8 Re: CV Joints are going i believe
    Aug 2008
    Quote Originally Posted by Liquifire View Post
    yea ill check them out when i do it i guess. so for now ill order the boots and grease
  9. #9 Re: CV Joints are going i believe
    May 2008
    staten island,NY
    if you happen to pull the output shaft out of the trans dont!!! the ring clip will damage the oil slinger in the trans and your diff will blow to pieces...experience lad...good luck
  10. #10 Re: CV Joints are going i believe
    Aug 2008
    Quote Originally Posted by QwikGT View Post
    ok nick, thanks for the advice. i think im just gonna buy a new axle though not a new boot just in case theres actually something wrong with the joint itself. wheres a good place to buy the new axle? i dont wanna buy a piece of **** thats gonna break in 6 months
  11. #11 Re: CV Joints are going i believe
    Joliet, IL
    are you saying not to pry it out (crowbar method) i always thought that seemed too forceful.....im assuming tappin it out is a better method...
    00 Silvermist GTP
  12. #12 Re: CV Joints are going i believe
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by BoostJunki3 View Post
    You don't necessarily put much force on it. Just enough pressure and then tapping to get the ring to pop out. I do it by hand first and if that doesn't work then put a small bar in there and a couple of yanks then maybe a rotation of the axle and it should come out.
  13. #13 Re: CV Joints are going i believe
    Wausau, WI
    how much do you want to pay? LOL
    They have bullet proof shafts at sfphq but they are like 250 or 300 each...but they look like the best I have seen
  14. #14 Re: CV Joints are going i believe
    Aug 2008
    dont wann pay a whole lot haha. hopefully no more than 100 each would be good. you dont have to change both at the same time right?
  15. #15 Re: CV Joints are going i believe
    Wausau, WI
    they are independant and you only have to replace one at a time.
  16. #16 Re: CV Joints are going i believe
    Aug 2008
    i think im just gonna order a passenger side "stage 1" axle from zzp. its suppose to be a stock replacement
  17. #17 Re: CV Joints are going i believe
    May 2008
    staten island,NY
    i got mine from ZZP
  18. #18 Re: CV Joints are going i believe
    Wausau, WI
    i got mine from ZZP
    and? how long have you had it? how many miles? has it worked well for you? is there anything that you didn't like about it?
  19. #19 Re: CV Joints are going i believe
    May 2008
    staten island,NY
    drivers side i replaced 3 years ago, passenger side last year because i have a hd diff now. worked out well
  20. #20 Re: CV Joints are going i believe
    Aug 2008
    yea just ordered it. zzp is usually good about shipping too so i wouldnt be suprised of it gets here monday and hopefully ill install it some time that week. gotta get it done before i go to the track nov 7th!
  1. I need Realible CV joints w/ Slicks...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2009, 08:09 PM
  2. Who in here is still on Original GM CV joints???
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-04-2009, 08:30 PM
  3. Replacing Ball Joints
    By 98GTPCALGARY in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 05:12 PM
  4. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
  5. CV joints
    By JCG's-GTP in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2008, 11:29 PM
