Thread: mps pulley/belt alignment.
Results 1 to 5 of 5
  1. #1 mps pulley/belt alignment.
    Joliet, IL
    on a 8 rib zzp mps pulley does a 6 rib belt sit on the middle 6 ridges.... or inner 6/outer6 i have mine in the middle no issues seems most lined up this way...only asking because of the wear lines on that 3.5 mps for sale in the FS section....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: mps pulley/belt alignment.
    Charles City, IA
    They just line up how they want. I don't no why it sat like that on my 3.5, it sits on the middle of my 3.4
    SMGPFC Two Nipple General
  3. #3 Re: mps pulley/belt alignment.
    line it up in the middle. if your hub is a little offset the belt will move itself. trust me, i know.
  4. #4 Re: mps pulley/belt alignment.
    Wausau, WI
    mine sits in the middle.
  5. #5 Re: mps pulley/belt alignment.
    It'll move to align itself with the rest of the pulleys...if you have it offset and have someone start the car and watch it...you can see it move the correct amount of notches.
  1. new belt w/ smaller pulley?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 05:54 AM
  2. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
