Thread: car wont start after top end put back on.
Results 1 to 4 of 4
  1. #1 car wont start after top end put back on.
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Ok so i had either a head gasket or tb gasket go bad causing antifreeze in the cylinders so i tore it down and replaced the head gaskets and put different stock heads on cause mine were cracked very badly the mechanic said. Anyway i put it all back together made sure everything was trq correctly and i tune the pcm for the e85 and such and go to start the car and it just turns over. does not even try to fire. I am getting fuel and spark. What am i missing? Could i have ruined the block with the antifreeze going in there when i was driving making the piston rings go to hell and not giving me any compression? im at a loss. I checked all the connection change plugs and the car still does the same. The fuel pump primes right up and you can here the rail filling with fuel and such. The started just fine before this all happen? The block was left in the car and i just put everything back on it. i dk what im missing someone help me out please.
    thank you
    Just your normal 730whp 4dr family car.
  2. #2 Re: car wont start after top end put back on.
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    Fuel, spark and compression are all needed for your engine to run. Did you have to do anything with the timing chain while you were in there? You also might want to try resetting the PCM with a battery disconnect.
    Hopefully, there is a simple thing that you are overlooking that will jump out at you after taking a break.
    Don
  3. #3 Re: car wont start after top end put back on.
    Donating Users Liquifire's Avatar
    Wausau, WI
    Are you getting air in there or did you check to see if the TB opens? If you have fuel, air and spark, it should run...
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  4. #4 Re: car wont start after top end put back on.
    Dec 2008
    Sioux Falls,SD
    1. we checked all the VAC lines (correct)
    2. checked all spark plug wire (correct) and getting spark
    3. check for fuel (getting plenty)
    4. checked and unplugged all electrical even went as far as the crank sensor
    5. compression test results
    1 cylinder=150
    2 cylinder=120
    3 cylinder=130
    4 cylinder=120
    5 cylinder=130
    6 cylinder=150
    6. Out of desperation sprayed some e85 in the s/c with the TB open nothing happen
    7. Troubleshoot it some more trying to find why it wont fire and just for the hell of it we spray STARTING FLUID in the s/c with TB open and instantly it fired and idled like a kitten. shut it off and turned it back on and fired right up again. WOW e85 and dry parts i guess dont work to well.
    thanks for all the help!
  1. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  2. put it back together, now wont run
    By 99gpse in forum General Tech Discussion
    Last Post: 02-20-2009, 07:06 PM
  3. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  4. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
