Thread: tail lamps have moisture
Results 1 to 4 of 4
  1. #1 tail lamps have moisture
    i noticed my tail lamps are having condensation inside after sitting in the rain or washing ,i have checked for cracks in the housing,none to be found, any ideas,the vehicle was always garaged...........is the a seal which surronds the tailight top ,possibly the seal is distorted due to drying out ???? i am a bmw tech and find this fustrating,also the insides of the lens is getting discolored ,any way to clean ................my car is pristine and this fustrates me,vehicle has not had any body work done due to auto accident
  2. #2 Re: tail lamps have moisture
    Wausau, WI
    yes, the seal goes to hell and allows moisture in. This is very common. I am going to speak for Bio and say drill holes in the bottom of the taillight housings.
  3. #3 Re: tail lamps have moisture
  4. #4 Re: tail lamps have moisture
    Wausau, WI
    I did see somewhere on this website a thread where the person took them apart and resealed them shut after cleaning out all of the moisture. Those are about the only other options short of getting new ones or used ones w/ good seals.
  1. Water/Moisture on Inside of Tail light
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 05-22-2018, 10:11 PM
  2. Moisture in the head/taillights
    By Ninjo in forum General Tech Discussion
    Last Post: 10-12-2013, 09:24 AM
  3. Halo's Have Moisture
    By mikroehl in forum Visual/Body Modifications
    Last Post: 03-22-2009, 07:35 AM
  4. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
  5. L.E.D Tail lamps
    Last Post: 02-09-2008, 05:34 PM
