Kind of a hard place to take a pic, i'll see if I can try.
All you need to do is use one shim on the door side of the hinge. There are 2 bolts holding the hinge to the door, back off the 2 bolts some, have a buddy lift up on the door, insert a shim on the lower bolt between the door and the hinge, tighten up the bolts. Nothing much to it......
