are you talk about when you open you're door it sags a bit? If so, mine did the same thing and it started on the passenger side. I took it in to a shop and they said that I hit something. I was like yaa okay! Well one day my gf couldnt get the door closed because the door was clipping the front fender! Bent the hell out of it Anyways to my fix, i went to a junkyard and took some door hinges off a 2 door and put them on mine. It seem that the bottom hinge is the one that gives out. When you remove it you can see theres a lot of play up and down. Hope this helps and saves you a front fender lol.
