I have a 2000 Grand Prix and I need to replace the ignition switch. My question is since its a passkey 3, will I be able to reprogram it and if so How do I do this?
Thanks A bunch
Thanks A bunch
PLEASE POST IN THE CORRECT SECTION.
4. Put emergency brake on to disable daytime running lights (this step is required!)
5. Make sure all doors trunk and hood are closed leave driver window down and reach in threw window
6. Try to start. If it doesn't start, leave the key in the on position for 10 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn off after this amount of time.
7. Turn off ignition for 3 seconds
8. Try and start the car. It probably won't start. Repeat step 5 two more times.
9. If this doesn't work disconnect battery for 5 seconds and then try and start the car.
