View Poll Results: would you buy copper head gaskets? They come in diff thicknesses
Voters
6. You may not vote on this poll
  • yes, i would buy em
    2 33.33%
  • no, dont waste your time.
    4 66.67%
Thread: Copper Head Gaskets
Results 1 to 14 of 14
  1. #1 Copper Head Gaskets
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    Ok guys i have an opportunity to have these made right down the street from me. I wanted to see how many people would be interested in buying copper gaskets. They will come in differant thicknesses as well for the different compressions, kinda like the layerd ones but i these will be solid copper. You guys use copper spray, why not just use copper gaskets. This is from a company who has been making gaskets since like 1920 or somthing close to that. I actually think its been longer. But any ways im not quite sure on the exact price, but just to give an idea ide say the price should be some were between... 80.00 to 140.00 thats just a guesstamate im trying to get them made cheap enough to be sold for a hell of a price that cant be beat..... So everyone please leave some feedback bc i need to know if i should even take the time to do it. bc if nobody wants them why do it you know.
  2. #2 Re: Copper Head Gaskets
    Stockers FTW. Get Felpro's.
  3. #3 Re: Copper Head Gaskets
    pittsburgh,pa
    Is there a reason y you wouldnt use them? Or do you just love the stock equipment?
  4. #4 Re: Copper Head Gaskets
    pittsburgh,pa
    These gaskets are used on blown top fuel dragsters,funnycars,streetrods,ect. Im sure they would hold up on the l67,36,26,32 ect.
  5. #5 Re: Copper Head Gaskets
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Quote Originally Posted by bigdawg15005 View Post
    Copper gaskets have a tendency to compress over time which requires you to retorque them periodically. They do allow you to run some mad power though.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  6. #6 Re: Copper Head Gaskets
    pittsburgh,pa
    If you dont like to have to do any work on it later, or should i say maintenance,Then u mayaswell just leave it stock and do regular maintenance to it,oil change,plugs,wires, lol..Its alot easier to tighten them up then it is to replace the timing chain dampner,and people do it ...and its reusable, so for those of you who get the arp head studs and are always pulling your heads you wouldnt have the extra expence of the gaskets, to go with those arp bolts. But anyways Finally somone agrees with me.....hahaaha......thanks.
  7. #7 Re: Copper Head Gaskets
    Schaumburg, IL
    Headgaskets aren't a maintenace item. Once you install them, you shouldn't have to check up on them. A double roller timing chain solves the tensioner issue. MLS gaskets are reusable and are proven to work once you have them sealed. Hell if MLS gaskets can hold up to an 8 sec grand prix, thats good enough for me.
  8. #8 Re: Copper Head Gaskets
    They have leaked before...the stock ones run with no issues...unless your pushing like 90 psi or something they aren't gonna go bad.
  9. #9 Re: Copper Head Gaskets
    pittsburgh,pa
    well fuc* it.i wont wast my time then. It was just an idea that my friend ran by me. figured i would ask................
  10. #10 Re: Copper Head Gaskets
    pittsburgh,pa
    ohh and by the way any head gasket will leak if its not done properly...dont matter what kind it is...and most people then use copper spray to help seal them......like the layered ones...and they buy the layered ones for diff compresion...so if you could get the compression you want with better sealability...then y not ? and at half the cost..idk just a thought.
  11. #11 Re: Copper Head Gaskets
    SE Level Member E90 87SS GTP's Avatar
    NJ
    fel pro with printo seal if they make them for your application
  12. #12 Re: Copper Head Gaskets
    the 550+ whp whipple car is running felpros. you dont need metal head gaskets.
  13. #13 Re: Copper Head Gaskets
    pittsburgh,pa
    There not made from solid copper metal. its a mostly copper base....
  1. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  2. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  3. cylinder head gaskets
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2008, 09:33 AM
  4. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
