From partsamerica.com
System Reports Comments
Engine Significant Problems Occasional problems with this vehicle are failures of the Fuel Pump Resistor, 3.8L vin 1 supercharged engine only, the Upper and Lower Intake Manifold, 3.8L vin K engine only, the Fuel Injectors, 3.1L vin M engine only, and a periodic problem is failure of the Camshaft, 3.1L vin M engines only. Failure of the Fuel Pump Resistor will prevent the vehicle from starting.
Transmission & Driveline Moderate Problems An occasional problem with this vehicle is failure of the Transmission Pressure Control Solenoid (PCS). Failure of the Transmission PCS is identified in TSB # 00-07-30-002B.
Starting & Charging Moderate Problems An occasional problem with this vehicle is failure of the Ignition Switch.
Accessories Moderate Problems An occasional problem with this vehicle is failure of the Wiper Motor Crank Arm Assembly.
