Thread: Front O2 sensor
Results 1 to 9 of 9
  1. #1 Front O2 sensor
    Ohio
    I know its a pretty easy fix but is there a DIY on the front 02 sensor replacement? If so could you post a link..The part that corn-fuses me is the application of the Goop and I dont want to screw this up .
    Thanks..
  2. #2 Re: Front O2 sensor
    Application of the GOOP? All you do is unscrew the old one...put a little bit of Anti-Seize on the threads of the new one and tighten it back down and plug it back in...thats it.
  3. #3 Re: Front O2 sensor
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    it is such an easy repair i dont think anyone has ever needed a write up for it. what do you mean by Goop? the goop i remember was for washing really dirty hands. you may want to apply a little bit of anti-seize compound on the threads before installing the new sensor....
    edit: for what its worth.... http://en.wikipedia.org/wiki/Goop
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Front O2 sensor
    Barksdale AFB, LA
    Even easier, if you buy a GM sensor (which you should since a lot of GM cars don't like Bosch sensors), the anti-seize comes on the threads.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Front O2 sensor
    Ohio
    The Goop was the Anti-Seize..I just called it goop, figured you would know what I was talking about, But thanks for going to the extent of wik for the definition of Goop Jake that helped a bunch.
    Anways..Thanks for the advise guys, I will look into the GM version..
  6. #6 Re: Front O2 sensor
    Quote Originally Posted by Sabrewings View Post
    My car LOVES my Bosch sensor...it hated the stock one
  7. #7 Re: Front O2 sensor
    Guam
    Make sure you have the proper Oxygen sensor socket to remvoe the old and install the new. Makes the job so much easier!
  8. #8 Re: Front O2 sensor
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    It is a bit of a pain if it has never been out before, but is straight forward. Roll the engine forward to give more access to it, and use a socket designed for O2 sensors. You will probably need an extension or two, and a breaker bar helps because it has a swivel built in.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: Front O2 sensor
    Ohio
    Yeah, Piece of cake . But I will try it myself, just dont want to blow a 40-50 dllr part trying to be MR FIX IT, when I am a Noob..
  1. Front Knock Sensor Removal Question
    By nickbuol in forum General Tech Discussion
    Last Post: 07-23-2009, 08:22 AM
  2. No o2 sensor ??
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-07-2009, 05:55 PM
  3. ? about my maf sensor
    By ponycarman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-04-2009, 11:39 AM
  4. Iat sensor ?
    By GTP4 in forum PCM Tuning
    Last Post: 10-18-2008, 11:14 AM
  5. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
